Gen5DIY
Old 04-08-2018, 07:57 PM   #1
nortonyaya
Drives: 2013 ZL1
Angry Outer/inner boot ZL1
Hi,
My Name is Norton from Germany.
I drive a 2013 ZL1.
Last Tuesday on my 3rd Inspection,
i saw that the inner boot ( rear axle, right side)
Is damaged!
If i choose my car at gmpartsonline there isn't
an inner boot for my car ...
Just the complette ( 22953759) axle assembly !
But the axle is okay !
There is the outer boot (92228290) and i think
the outer is the same like the inner ...BUT
the next Problem is that the partnumber is
the same as the Camaro SS outer boot!
When i choose the ZL1 at your Vehicle,
there is written ...
outer boot right W/ZL1 (at the Part List) ! That's what i need !(I hope)
But in product details is written without ZL1 !?
I know that the SS and ZL1 have different axles.
So what i have to Do ?
Choose my car and order the outer boot W/ZL1?
The link:
https://www.gmpartsonline.net/oem-pa...YtMmwtdjgtZ2Fz
Please help me
nortonyaya is offline   Reply With Quote
Old 04-09-2018, 09:06 AM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
The part # is correct for the outer boot on the ZL1, the inner is not listed. Maybe someone who works at a dealer (parts counter) will chime in.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 04-09-2018, 11:48 AM   #3
BlackMambaZL1
Drives: 2013 ZL1 Black
IMHO and personal experience of replacing many axles; the amount of time that it takes to rebuild the seals and clean it all out you would be money ahead to do a new axle. To get all the grease cleaned up and redone is dang near impossible to get all of the impurities out and they will cause a failure in the seal if not properly cleaned.
I know the axles are expensive, especially being shipped to Europe haha. But, more bad than good usually happens when only replacing CV axle boots.
764RWHP on e85 683RWHP on 91. M6 Black on Black on Black. 1300ID's, DSX Aux Pump and Flex Fuel Sensor, Lingenfelter 2.5 upper 9.5 lower, 100MM idler, AFCO HX w/ FANS. 1 7/8"ARH exhaust to axle incl LTH, MF's, Fuel Lab FF, Lingenfelter ported snout and TB, Lingenfelter CAI, RotoFab coolant tank, NGK 2 steps colder spark plugs, Moroso catch can, BTR Stage III cam, crank case breather. Tuned by Power Labs in Idaho Falls, ID.
BlackMambaZL1 is offline   Reply With Quote
Old 04-09-2018, 03:40 PM   #4
DrkPhx
DrkPhx's Avatar
I agree 100%. Last year I found a tear in the driver side axle outer boot and it was spraying grease every where. I bought what I thought was a ZL1 specific boot replacement kit but it was for the SS. Contacted another dealer who said they do not have a boot replacement kit for the ZL1. So I bought a generic kit and attempted to make it fit. What a major PITA to tear apart the axle. It didn't work so I bought a new axle and installed it and call it a day. Check ebay for used axles. They are much cheaper than new and should work fine.
Old 04-09-2018, 03:47 PM   #5
nortonyaya
Drives: 2013 ZL1
Is the outer ZL1 boot Same like the inner?
Old 04-09-2018, 03:49 PM   #6
nortonyaya
Drives: 2013 ZL1
Is the outer boot same like the inner ?
