10-05-2014, 09:11 PM | #1 |
Drives: 2010 Camaro SS/RS LS3 Join Date: Sep 2014
Who has maguson supercharger?
Who here has the maguson supercharger on a LS3? Want to do some upgrades to my car but the guys at maguson say I can't change the stock items on my car besides the CAI I already have. Thought it might be easier to find folks with the same supercharger and get the inside on the do's and donts.
10-05-2014, 10:42 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2012
Lots of people do! You may want to have this moved to the forced induction forum you'll get significantly more responses
10-06-2014, 06:02 AM | #3 |
Too much is never enough!
I was doing some research about a year ago on a Supercharger kit. I was communicating with a tech at Whipple. Looking at different options to add on to the kit. Such as CAI and headers, along with a few other things. I asked the guy about installing a few bolt ons and he told me that the kit's hand held flasher did not have the tune for it. If I wanted to add those things I would need to take it to a dyno shop and have it tuned. They only tuned for simple factory components.
That may be what your running into. If that's the case, don't worry about it.
10-07-2014, 07:07 PM | #4 |
Drives: 2012 Camaro 2SS / RS Join Date: Feb 2013
I am running a TVS 2300 with 2inch long tube headers and a full 3inch exhaust, 160 degree termostat and some other goodies. I got a custom dyno tune, don't use the supplied one, spend a couple extra bucks for the proper tune.
10-07-2014, 08:49 PM | #5 | |
