Old 03-21-2021, 12:01 PM   #1
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Front bumper removal problem
I’m removing the front bumper to install a heritage grill and tranny cooler but I ran into a problem. The top bolt on each side just keeps spinning. The bumper is just hanging on by those 2 bolts and I see in the gap of the fender and bumper the threads that are inside the bumper are just spinning. Is there a easy way to get them out? All I have is a saws all to cut them but can’t fit the blade inside fender wall to cut them.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-21-2021, 01:10 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
The only way that I know you could get these out besides cutting them is to apply a little pressure outwards on the head of the bolt with something to get the threads started backing out. It’s a very tight place though.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, SLP loudmouth exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 03-21-2021, 02:27 PM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2017 Colorado, 2013 2SS
Or outwards pressure on the bumper might work. Good luck.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-21-2021, 02:46 PM   #4
smokehippielettuce
smokehippielettuce's Avatar
Drives: 2012 Chevy Camaro rs
Can't wait to see pics! Ive been thinking of doing that to my car. Did you paint it to match?
smokehippielettuce is offline   Reply With Quote
Old 03-21-2021, 03:08 PM   #5
Bigdumogre
Bigdumogre's Avatar
I tried using a screwdriver wrapped in rags to try and apply pressure to the bumper and try to get pressure to get it out to no avail. I also tried a screwdriver in the back but it’s such a tight place I couldn’t get it good enough using hand tools. If I had a air ratchet it would maybe be easier.
I put my car back together for now and will retry in a few days when I get some good ideas to try lol.
I dident paint to match I left it the stock color just like my old OEM grill.
Old 03-21-2021, 03:42 PM   #6
Camaro2ss2010
I have taken some fast setting glue and glue the socket to something like this that I could not get behind. It shouldn’t be so tight that it breaks the glue loose before catching the threads. Just another thought.
Old 03-21-2021, 04:53 PM   #7
Bigdumogre
Bigdumogre's Avatar
That might be a idea. I got it half way out the bolt so when the bumper and fender separates I can see the nut spinning. Maybe I can try and glue it and try again.
Old 03-21-2021, 04:56 PM   #8
BLU DUCE
BLU DUCE's Avatar
If they are the ones way up in the front. I had one do that. So I got a pair of needle nose vise grips and a small blade screw driver and put pressure under the head of the bolt when turning it. When I take mine off I jack the car up and take my tires off and the inner wheel well off. A lot easier to get to the screws.
Old 03-21-2021, 05:11 PM   #9
TheFlyingBananaSS
Buy new brackets to put in and saw of the old.
Old 03-21-2021, 05:53 PM   #10
Bigdumogre
Bigdumogre's Avatar
Ya I removed the wheels to and made the access as good as it can get. Maybe I’ll try that I used just a screwdriver to add pressure and couldn’t get enough to apply pressure and work a ratchet at the same time.
Old 03-21-2021, 05:54 PM   #11
Bigdumogre
Bigdumogre's Avatar
That’s why I was trying the sawsall but the location is horrible. Know any mini saws that would fit? I don’t mind drilling out the old and making it work again.
Old 03-21-2021, 06:40 PM   #12
Camaro2ss2010
You may can use a pneumatic saw if you have a strong enough compressor to run it.
Old 03-21-2021, 06:48 PM   #13
Bigdumogre
Bigdumogre's Avatar
That I don’t just some hand tools and time on my hands lol. A small cutting wheel would do it in a second.
I even tried to retighten time and snap the bolt that way to no avail.
Old 03-21-2021, 06:50 PM   #14
Bigdumogre
Bigdumogre's Avatar
Would something like this work? I have a good drill
https://www.amazon.com/Rotary-Cuttin...s%2C154&sr=8-6
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
