Old 12-01-2021, 09:03 AM   #1
Briandavis317
Drives: 2010 Chevrolet Camaro 2ss
480-500 rwhp 2010 ss automatic
To get the best bang for my buck out of my stock 2010 camaro 2ss n/a im putting a n/a Texas speed cam in with a new valve spring kit .660 springs, I’m getting a torque converter, I don’t remember the stall but I have a guy who’s putting that in based on the hp I want, does anyone have any recommendations on compression ratio if I should up it or not (i don’t want to go stroker), what n/a cam should I get, are the valve springs correct? Also I understand for automatics it’s very hard to hit 500 rwhp so if that’s Unachieveable with my parameters I’m not super concerned. P.s. I’m getting new pushrods, gaskets, vvt delete kit, afm/dod delete kit, new timing kit and cover, melling high pressure oil pump, I already have tsp heads as well, I believe the headers are 1 7/8 but I can’t remember but it is long tube catless, and new lifters and trays.
Briandavis317 is offline   Reply With Quote
Old 12-01-2021, 09:09 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have the TSP Stage 3 cam, 231/246 @112 LSA with stock heads and an LOD X-1 intake manifold and running a 4200-4500 Circle D converter, ZL1 fuel pump and my numbers are in my sig... Nice cam..
Old 12-01-2021, 03:28 PM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2017 Colorado, 2013 2SS
Boost it!
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 12-01-2021, 05:31 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by TheFlyingBananaSS View Post
Boost it!
lol yep!! That will work. I wanted to do mine, but having to retire last year due to COVID hitting the aircraft industry really hard, my money tree died.. So I won't be doing that like I wanted to. Gotta watch my little money bushes now.. hehe.. And I'm NOT going back to work just for that! I like being retired!!
Old 12-01-2021, 09:52 PM   #5
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM 2399
Your car is plenty bad ass without boost!
Mine is going to get an LSA blower sooner or later for sure.
”Blue”ABM #2399, 2010 2SS/RS: GM GFX, GM Heritage, GM dovetail, Silver Ice Rally stripes.
‘87 IROC-Z all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 12-01-2021, 11:03 PM   #6
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Boost it!!!
Mod sickness
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 12-02-2021, 06:32 AM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
I got 500 rwhp with a supercharger and not going into the engine on our 2010 Camaro 2SS. Headers, tune, zl1 fuel pump.
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 12-02-2021, 08:18 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
lol yes she is!! I DO give the boosted guys a run for their money, even the Hellkitty's... haha.. Thanks my friend!!
Old 12-02-2021, 10:16 AM   #9
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
You would probably be close with a TSP F35 cam, PRC 260 heads, and a holley high ram intake manifold. Not gonna do it with stock heads on an auto.
SSkat is offline   Reply With Quote
Old 12-02-2021, 02:46 PM   #10
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
500whp NA is really not achievable without a stroker, heads , cam, intake with a larger throttle body. Many people hit the 460+ and with a higher stall convertor it will feel like it’s 500hp
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 12-02-2021, 07:35 PM   #11
InFiD3ViL
InFiD3ViL's Avatar
I think it would be very possible on aftermarket heads and intake with a donkey dick LLSR build.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7º overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels - Tuned by Ryan @ GPI via HP Tuners
Old 12-02-2021, 09:56 PM   #12
Royal Tiger
Sd Kfz 182
Royal Tiger's Avatar
Drives: 2013 2SS/RS Convertible
Boost it!
That’s what I decided to do. I can’t wait to try it after Ted Jennetty gets his hands on it.
Royal Tiger is offline   Reply With Quote
Old 12-03-2021, 06:06 AM   #13
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I know of somebody who hit 500 hp with that combo. But it was a manual.
GPI SS1 Camshaft with vvt, GM Performance racing lifters, CHE trunnion upgrade, TSP Chrome Molly pushrods, Pac Polished .660 valve springs, Melling 10355HV oil pump, Cold Air Inductions cai, TSP 1 7/8" longtubes with 3" exhaust, true cool 40k tranny cooler, ebc brakes
morepowerjoe is offline   Reply With Quote
Old 12-10-2021, 05:45 PM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
KEEP VVT....unless you are just chasing numbers.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
