Old 01-07-2014, 06:21 PM   #1
kanddr
kanddr's Avatar
Drives: 2011 SS/RS M6
Redline 75W90 for differential question
I want to change the fluid in my differential and I think I want to go with Redline 75W90. It says it doesnt need any additional friction modifier added but I want to know from those that have used this if they needed any or not?
kanddr is offline   Reply With Quote
Old 01-07-2014, 10:09 PM   #2
STSL
Drives: 2010 ZR1 Camaro
I would stick with the factory stuff with the factory diff
STSL is offline   Reply With Quote
Old 01-08-2014, 12:35 AM   #3
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
I used it no friction modifier no noise no issues 18000 mile on my vert
12000 on my silvy
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 01-08-2014, 01:11 AM   #4
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Used it here fine no problems. Seems smoother.
BigBlock69RS is offline   Reply With Quote
Old 01-08-2014, 05:58 AM   #5
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
No problems and no additional additives for 10,000 miles. Put it in at 500 miles when I did gear swap to AAM 3.91s. Very quiet, no noise at all.
Also use Redline D4 ATF in my M6. Had 2nd gear grinding issues from the beginning until trans would warm up. Tried all the others (GM, Mobile1, Royal Purple). Redline made the most difference especially when trans temp was < 180*.
toml_pa is offline   Reply With Quote
Old 01-08-2014, 08:40 AM   #6
kanddr
kanddr's Avatar
Funny you mention that because I'm changing over to the D4 in my M6 for that exact reason. I figured once the car was up in the air I'd do the differential at the same time.
