11-24-2021, 10:15 AM | #1 |
Drives: '10 Camaro SS Join Date: May 2019
About front O2 sensor delete
Hi. Camaro L99 engine with long tube headers, no cat, and cai. Nothing else and it is a daily driving car. My tuner delete the front o2 sensors because one of them stop working. Car runs just fine about 1 year. Is there anything wrong with them? Is it safe to drive for daily drive or should I replace the oxygen sensors and retune?
11-24-2021, 10:21 AM | #2 |
And how can i tell my front o2 sensor are disabled? I think front o2's are for short term fuel trim. I was check my stft and ltft from obd scanner and it looks ok to me?
11-24-2021, 11:01 AM | #3 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If you are seeing STFT or LTFT readings from both banks, then they are working.
You would not want to delete the front 02 sensors. The rears can be deleted, and there are some codes specific to the front 02 sensors that need to be removed from the tune, but your car cant make closed loop fueling changes without the front 02 sensors.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-25-2021, 08:53 AM | #4 | |
11-25-2021, 11:45 AM | #5 | |
01-07-2022, 03:45 PM | #6 | |
I suggest you replace them with new and retune. Ted.
www.jannettyracing.com
01-07-2022, 04:53 PM | #7 |
^^^^ this, the best advice you will ever get, right there. You will be amazed at how much "better" your car will run with the sensors and ecu connecting/working properly!! You might think it is running fine, but it isn't really.
