#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 02-06-2017, 11:36 AM   #1
KirkH
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD
DIY: Glass replacement outside mirrors
This job is a piece of cake!
To replace the glass on an outside mirror:
The glass has a plastic "frame" on the back of the glass. It snaps over the mirror motor to hold the glass in place. There are no tabs or levers to disengage with a tool.
Remove the old glass- Push mirror to the inside. Pull out on glass with hand to disengage plastic frame from mirror motor.
Install the new glass- Center the plastic frame over the mirror motor and push glass with hand to snap into place.
KirkH is offline   Reply With Quote
Old 09-18-2017, 11:37 AM   #2
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
Have any pics of the back of the mirror (glass) or the mirror housing?
When you say "push mirror to the inside" I assume you mean push in (or if power mirror move in) on the glass that is closest to the car, which will provide a point on the outer edge (furthest from car) of the glass to "pop" out the glass?
I want to remove the glass so I can paint the mirrors but am worried I'll end up breaking the glass.
ride98red is offline   Reply With Quote
Old 09-20-2017, 06:10 AM   #3
KirkH
The back of the mirror has a plastic socket that fits on a ball on the mirror motor, like a shoulder joint.
Old 10-08-2018, 11:19 AM   #4
17txcamaross
Drives: 2017 Camaro 2SS
I know this is an old post, but thank you for this information. Will be using this afternoon when I pick up my new mirror housing from paint.
17txcamaross is offline   Reply With Quote
Old 10-13-2018, 11:59 PM   #5
KirkH
Old 12-29-2018, 09:14 AM   #6
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
We used to have for right side mirror one that said "objects in mirror are slower than they appear". Sofia find one this seems easy to swap out.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 05-24-2021, 04:10 PM   #7
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
Once glass is out do you think the mirror can be taken apart totally to make a mold to make the mirror out of carbon fiber?
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 05-25-2021, 06:06 AM   #8
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
It can be taken apart, this is a few years old but this is my mirror with the broken internal structure circled in red. All other parts are not broken and taken apart, I had removed it from the door panel though
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 05-25-2021, 09:35 AM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That's awesome Thanks.. was it all clips and screws or did you have to get things hot/melted to separate?
Old 05-25-2021, 06:43 PM   #10
Bumbleboy92
Long hauler
Only screws I remember were the 3 holding the entire mirror to the door that you reach from inside the door panel, everything else is clips
2016 1LT v6
- Totaled
Happiness: Infinite
