Old 09-27-2020, 11:53 AM   #1
CHRISCAM
CHRISCAM's Avatar
Drives: 2013 Summit White 2SS/1LE
75W 90 Gear Oil for TR6060?
I'm about ready to do a rear end and trans oil change so I've been reviewing a lot of the older threads regarding recommended oils for both. I've seen some conflicting information (I know, big surprise with so many people offering their opinions!). However, this is a pretty serious subject, as using the incorrect type could obviously damage the parts.
This thread pasted below mentions that some are using the same 75W90 gear oil in both the rear diff. AND the trans. How can that be good for the trans if GM recommends Dexron ATF (or alternately Tremec recommends Mobil 1 synthetic ATF)-- both of which MUST have much lower viscosity that 75W90 gear oil! What am I missing here?
https://www.camaro5.com/forums/showt...=519041&page=2
CHRISCAM is offline   Reply With Quote
Old 09-27-2020, 01:45 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
That doesn't make sense. I know I would hardly be able to shift if I ran gear oil in the trans. You definitely want an ATF, I have had decent luck with Redline.
You also want to make sure you have a gear oil with friction modifiers for a limited slip differential, some include it and some you have to add it separately.
Sent from my Pixel XL using Tapatalk
Old 09-27-2020, 02:35 PM   #3
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
The manual trans difference between V6(gear oil) & V8(ATF)
SIM GhostrdrZ is offline   Reply With Quote
Old 09-27-2020, 04:06 PM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
For a TR6060 use Redline D4 atf.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 09-27-2020, 07:18 PM   #5
CHRISCAM
CHRISCAM's Avatar
Thanks guys, for the input I was leaning toward using the Red Line ATF for the trans and their 75W90 oil (that evidently has the LS friction additives) for the rear end.
Chris
Old 09-28-2020, 06:55 PM   #6
Russell James
Russell James's Avatar
The diff uses gear oil, the trans uses manual trans lube.
I've had the best luck with Royal Purple 75w90 max gear in the diff. It already has the limited slip additive in it. And Royal Purple Synchromax in the TR6060 trans. It will shift a little smoother than the OE fluid. Easy to get both from Amazon. 2 for the diff, 4 for the trans. Fill each until it runs out the fill hole.
Old 09-28-2020, 07:53 PM   #7
SIM GhostrdrZ
The V6 manual transmission uses 75w90 gear oil. V6 and V8 manual transmissions are different and therefore call for different lubrication specifications.
Old 01-13-2021, 10:24 AM   #8
supersnake05
supersnake05's Avatar
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS
I know this is a little old but doing my own research I've read that royal purple is one of the only ones with friction modifiers in it. I know redline says it but I've read people using redline and mobil 1 having chattering issues. I'm going to use redline d4 atf for trans and royal purple max for the rear. The rear only holds 1 quart. You can buy a gallon of redline on Amazon for 43 dollars.
supersnake05 is offline   Reply With Quote
Old 01-13-2021, 11:00 AM   #9
gtstorey
I haven't had any chatter problems with Mobile 1 LS differential fluid. I did have a problem with the LUCAS. It says it's good for LS, but it doesn't have the friction modifiers.
Old 01-13-2021, 02:28 PM   #10
supersnake05
Good info. Like I said just some info I've read along the way.
