04-27-2010, 10:59 AM | #1 |
Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
CTS-V Motor Swap Questions (CTS-V Camaro)
I was thinking of putting a maggie on my camaro, but a CTS-V crate motor might be a better option for a couple of reasons like;
I can keep my factory motor and put it back. Basically I'm going to get the same power as if I put a maggie, but with stonger internal parts. The CTS-V motor is complete, and probably comes with a warantee !! Does anyone know if the CTS-V motor goes directly into the camaro with no addtional mods. For example the all the wiring is the same? All the plugs are there? Does the airbox line up? The CTS-V looks like it is off the the side. Does a CTS-V airbox fit in a camaro ? Any known issues? or unknown variables? Anything else you can think of?? Has anyone done it? Have you done it? Any pics? Any swap llinks? CTS-V crate motor links. http://www.gmperformanceparts.com/En...1708&engCat=ls http://gmperformancemotor.com/Mercha..._Code=19211708 http://paceperformance.com/index.asp...&ProdID=249801
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto |
04-27-2010, 11:10 AM | #2 |
Drives: C63 P31 Join Date: Feb 2010
Why don't you just build your motor with forged internals ($6,000) and install the Maggie ($6,500)?
I think LSA's go for $15,000. I'm not sure on that, though. So you could really save a bit of money. I do wonder if you installed the LSA, whether you would still have a powertrain warranty with your Camaro? Btw, I think it would be cool to install the LSA, I was just posting another alternative. You could probably get more power out of the forged internal/Maggie setup that I suggested. I'm pretty sure the Maggie is bigger than the blower on the LSA. Or you could install the Harrop on the L99 with some forged internals inside and make around the same power (and probably more torque) than the LSA. Regarding the air intake question -- whether the CAI of the LSA would line up in the Camaro? I think you could always make an air intake fit, even if it was custom made. And if you tuned the ECM (which you almost certainly would), the air intake that you made fit would still work well. |
04-27-2010, 11:47 AM | #3 |
Drives: pontiac g5 gt Join Date: Mar 2009
im pretty sure it can be done but it will cost you a arm and a leg. if you have the money i say do it. it will be a sweet project.
04-27-2010, 11:53 AM | #4 |
I am the internets.
The writing's on the wall--the LSA will be in the Z28. If you have that kinda coin and are worried about warranty, you should think about trading in the SS when the Z comes out.
04-27-2010, 11:59 AM | #5 |
Okie doke
If your going to do all of that go with a fully forged lsx engine not the LSA .. .. that is what I would do
Crowley
04-27-2010, 05:49 PM | #6 | ||
CTS-V motor swap, or not
I'm just throwing ideas out there. I'll probably just end up tossing the maggie on the top. Same result, a lot less money. Just not as stong of a lower end, but by then we should know if a factory L99 really holds up with a maggie on the top.
04-27-2010, 05:56 PM | #7 | |
SS Lightning
Drives: An SRT8 Join Date: Feb 2008
Ugh ... having the LSA in the Camaro is cool but going to add some weight
Last time I checked... the Bitch had 7 radiators from what I read Then you need the Transmission upgraded ... bigger brakes imho ... take it to LPE, they will do you rite
04-27-2010, 05:59 PM | #8 |
I am the internets.
Ah, didn't see that you have a TFE. LSA might be the way to go for you then, but check out the Edelbrock supercharger--very similar in design to the one on the LSA and it's safe to use with your existing bottom end.
05-10-2010, 09:41 AM | #9 |
Drives: SuperSport's Join Date: May 2009
Honestly if u have that kind of money just go get a C6 Z06 and dominate after a cam, cai & full exhaust
It would be cheaper to build ur motor, go Single tubo kit instead of a supercharger
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD" Plans : 2013 CamaroSS 1LE |
05-11-2010, 08:07 AM | #10 |
Drives: Speed Shop owner Join Date: Aug 2009
We can help figure this out if it's really the way you want to go. I have extensive experience with the CTSV and the Camaro, and it is way to involved to post in one shot! Feel free to call the shop and discuss 260-724-7792
Ed |
05-11-2010, 10:09 AM | #11 |
Petro-sexual
Intercooler cover needs to be modified. I'm sure there are going to be some wiring harness alterations and definately fuel system changes (dual-pressure system system like the ZR1 has). I think CamaroSpike23 was working with Uncle Robin on the transformation on Uncle's car.
I see your TFE and don't blame you Good luck with the project and keep us posted! |
05-11-2010, 10:42 AM | #12 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
05-20-2010, 10:35 PM | #13 |
Use the Force
A question just slightly off the mark. Is the 556 HP rating of the CTS-V Caddy a RWHP rating or a flywheel rating?
Walk softly, carry a light saber and drive a ZL1!
05-21-2010, 09:14 AM | #14 | |
Petro-sexual
There's no argument, from me, that LSA has a better foundation, but I don't want you to be suprised, power-wise. |
Similar Threads | ||||
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Cosmetics and Lighting Modification Discussions | 36 | 04-02-2020 05:32 PM |
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
