05-10-2017, 03:08 PM | #1 |
Drives: 2017 SS 6sp Join Date: Jun 2014
rear end fail
did the search but. I have the back lash whine when I let off the gas and coast down from 45-50 mph. went to dealer and got the stock answer (it's the tires).I will change lube but I don't think that will help. if I run it like it how prone to failure is this? I would like to do some lite drag racing and am worried about failure what are the odds
05-10-2017, 03:49 PM | #2 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
05-10-2017, 03:51 PM | #3 |
I have the same noise at the same speed and the dealer said the same thing to me... tires. Lol it ain't the tires!! At least they have a record of me ( you also) bringing it in for a rear end noise. I think this will help if there is ever a problem that develops and needs warranty work.
I think changing the fluid will definitely help although I haven't changed mine yet. How many miles on yours? |
05-10-2017, 04:34 PM | #4 |
Drives: 2015 ZL1 Join Date: Mar 2013
My 15 had a whine same as yours at 2500 miles dealer replaced the differential whine went away
05-10-2017, 06:44 PM | #5 |
Drives: 2015 ZL1 Join Date: May 2015
isnt there a service bulletin on this???
05-11-2017, 01:15 PM | #6 | |
05-11-2017, 01:22 PM | #7 |
05-11-2017, 02:28 PM | #8 |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Like Revster, I was lucky too and dealer replaced after 1,500 break-in as that is for both engine and rear diff. Replaced entire diff, faintest of noise out of new one, nothing even close to the old one.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
05-11-2017, 03:22 PM | #9 |
Drives: '15 ZL1 Join Date: Apr 2017
diff didn't fail.. this thread is a fail
05-11-2017, 04:49 PM | #10 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
05-11-2017, 10:20 PM | #11 |
05-12-2017, 01:37 AM | #12 |
Drives: 2015 ZL1 Join Date: Jun 2015
Dealer replaced ring and pinion @ 7000km. All good now!
2015 ZL1 M6
