04-19-2013, 03:29 PM | #1 |
Drives: 2011 camaro synergy Join Date: Sep 2012
Using USB
I've decided to say bye bye to XM. I bought a Sandisk Cruzer 8 GB flash drive and loaded about 6 GB to it. All are MP3 or WMA files.For some reason,some won't even show up on the play list. I see no difference in any of the properties of the files. Anyone have any ideas why this is???
04-19-2013, 07:44 PM | #2 | |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Page 7-20 of your Owners Manual Connecting and Controlling a USB Drive The infotainment system can only play back .mp3 and .wma files from a USB drive. Only the first 10,000 songs are recognized on the device. When a device is not supported, the message “No supported data found. You can safely disconnect the device” appears.
04-19-2013, 08:41 PM | #3 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
It also won't play protected files (ie: DRM). Which shouldn't be an issue, unless you are getting your files from your iTunes directory (or similar software) on your PC.
04-20-2013, 08:39 AM | #4 |
I've read all the information in the book. I have way less then 10,000 songs,and none are protected. If I let all songs play in random mode the songs will play,they just don't show up on the playlist.(ex. I have the box set of Led Zeppelin on it. Box 1,2,and4 show up. Box 3 doesn't. If I let all play,it will play songs from box 3. I'm thinking it's a software issue. What else could it be?
04-22-2013, 07:54 PM | #5 |
Sorry, I missed the playlist reference in the OP.
I've seen a few issues reported with playlists. Some of which are user created, such as creating a playlist and then moving songs to a different folder or removing the songs from the device. Which then essentially "breaks" the playlist. |
04-22-2013, 11:16 PM | #6 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
I believe the file limit for USB's is 2500 songs, not 10,000 as stated in the manual. I would think that you are not above 2500 songs on only 6gb but maybe you have small files amounting to over 2500? :\
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
04-24-2013, 03:39 PM | #7 |
Drives: 2012 Black Camaro LS Join Date: Jul 2012
I had a problem with some of the wave files not being formatted correctly. Once they were changed to MP3's, all of them showed up.
