Old 02-19-2017, 07:48 PM   #1
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Leather Steering Wheel / Shift Knob
Hey guys. Just ordered a matching leather steering wheel and shift knob from trunkmonkeyparts.com.
Black with stone stitching which will match my interior perfectly.
I think I got a really good deal at $264 shipped for both.
Was wondering how hard it will be to swap these in place of the urethane stock ones that come on the LS's
I think this will be a very tasteful upgrade. Assuming the knob will be easy but the wheel will be more complicated. Any help would be greatly appreciated!
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 02-19-2017, 08:24 PM   #2
Pete M
9 Year USMC Vet
Pete M's Avatar
Drives: 2014 1LT black on black
I used this for a guide when I upgraded mine
http://www.camaro5.com/forums/showthread.php?t=317592
Remember you HAVE to disco the battery and let it sit so you don't ger a face full of airbag.
Also, the spring clips you have to release go towards the outside of the wheel.
I used a thick wire clothes hanger instead of an Allen wrench.
It's easy once you've done it once..
Hahaha
A lot of stuff done so far to make it look better and be more fun to drive.....
Pete M is offline   Reply With Quote
Old 02-19-2017, 10:31 PM   #3
its Sparkyyy
its Sparkyyy's Avatar
Drives: 2012 V6 Summit White Camaro
I always turn the key when disconnecting my battery to make sure all the juice is out of the system then let it sit for 10 mins, but you can't take the key out until you plug the battery back up so keep that in mind
its Sparkyyy is offline   Reply With Quote
Old 02-20-2017, 08:30 AM   #4
sspade
sspade's Avatar
Thanks... that write up will be very helpful.
Any idea how to get the shift knob off?
Old 02-20-2017, 09:07 AM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Rotate the collar and pull down (think of like taking off a medicine safety cap, but pull up instead of push down)
Then there's a screw that you unscrew and pull the knob up.
... On second thought, this is assuming you are a manual, are you?
Here's some photos of my swap, I went and did suede, even the boot.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 02-20-2017, 11:52 AM   #6
sspade
sspade's Avatar
No, actually Im auto....
Old 02-22-2017, 06:24 PM   #7
Pete M
9 Year USMC Vet
Pete M's Avatar
Remember, when you disconnect the battery....
DO NOT CLOSE THE TRUNK!!!!!!!!
If you do, there will be Hell to pay trying to crawl through the back seat to reconnect the battery!!!!!
It only opens electrically
Old 02-22-2017, 06:48 PM   #8
sspade
sspade's Avatar
Good point...
Still hoping someone can give me direction on swapping out the auto shift knob.
By the way... the suede swap looks MINT. Wish I had gotten manual (for 2k less)... but at the time I didn't have a company car and thought I was going to be DD'ing the shit out of this Camaro. Now I only drive on weekends. Oh well.
Old 02-22-2017, 07:38 PM   #9
Pete M
9 Year USMC Vet
Pete M's Avatar
Good point...
Do a Google search on the shift knob swap.
You'll find what you need there
