04-13-2015, 07:19 PM | #1 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
**UPDATE**Droppin tranny at a stealership
so to drop a tranny at a local stealership(New Rochelle Chevrolet NY) its $1250
just to see whats wrong on a car that barely has 2k miles. They told me if I would have bought the car there they would have given me a discount I guess it doesnt matter that we have spent easily over 100k over the years. It other news found another dealership thats fixing all my issue ive been having for months under warranty no questions asked will update soon! Last edited by Bizaro; 04-14-2015 at 06:10 PM. Reason: update |
04-13-2015, 07:51 PM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Your sig shows you have a 2015. Why would they charge you, it's still under warranty. Even if you did not buy from them and they are a chevy stealership. Are you tuned or what's the story.
04-13-2015, 08:40 PM | #3 |
long story short bought this car and after about 1k miles started having transmission and clutch problems. Took it to several dealerships and none would want to touch it even though its brand new. Months later come today its gotten so bad that I cant drive it at all' clutch pedal doesn't return when engaged it returns 2 seconds later. so visited New Rochelle chevy they finally said they would take a look at it if I was willing to pay 1250 since cheap'o Chevy doesnt warranty clutches.
04-13-2015, 09:04 PM | #4 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Clutches are under warranty for 12 months or 12,000miles from the factory.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
04-13-2015, 11:23 PM | #5 |
They said they wouldn't cover it since its wearable item such as brakes
04-13-2015, 11:28 PM | #6 |
Too much is never enough!
The brakes on my truck were warrantied for the first 10k miles only. I think all items on our cars are covered for some length of time, its just a matter of how long, even the consumables.
Get another opinion, they may just be looking at dollar signs when they see you after dropping 100k.....
04-14-2015, 12:10 PM | #7 |
I would call GM customer care line and complain
04-14-2015, 12:41 PM | #8 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
04-14-2015, 03:24 PM | #9 |
GM is aware of my thread and they know they have a big problem on their hands. Mine was a bad clutch and Balue's was needing a vented reservoir cap. Go drive your car and get the pedal to not return. Dont bring the pedal back up leave it where it is then remove your cap if the pedal returns then its your cap if not then probably your clutch.
04-14-2015, 04:10 PM | #10 |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
LOL Yeah, let's not even get started on GMCS on this issue................(crickets chirping)......................................... .................................................. ...
04-14-2015, 06:09 PM | #11 |
So got a call from Paul Masse Chevrolet today they told me they are going to be replacing my clutch on warranty and then narrow down by gear grinding issue So a BIG thumps up to them! they also gave me a heads up and told me New Rochelle Chevy Stealership had my car flagged for clutch abuse WOW!!!!!!!! I cannot believe the nerve of those people HORRIBLE HORRIBLE HORRIBLE DEALERSHIP
04-14-2015, 07:07 PM | #12 |
Drives: 2015 CRT 2SS/RS 1LE Join Date: Feb 2014
Wow, I'd be absolutely ticked with that dealership. Can you get that flag removed?
04-14-2015, 07:26 PM | #13 |
yeah I dont know how these flags work but im guessing its gone now since the clutch is being fixed under warranty regardless just seems like a dick move on their part for trying to discredit me with other dealers.
04-14-2015, 08:08 PM | #14 | |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
