01-21-2019, 06:00 AM | #1 |
Drives: 12SS Join Date: Apr 2010
Check Engine Light
This morning I was getting ready to start my car with the remote starter and warm up a little bit because it is 35 degrees here in the Houston area. I know that’s not cold to some of you. It wouldn’t start, so I stuck the key in the ignition and it started but seemed to struggle a little at first. When I got in it to go home the check engine light is on. It runs great but the light is on. I did check the gas cap. How would I find out why the light is on?
01-21-2019, 06:30 AM | #2 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
autozone and certain other places will scan it and give you the codes for free,so will aammco.
01-21-2019, 06:35 AM | #3 |
Thanks for the help.
01-21-2019, 08:19 AM | #4 |
Drives: Camaro V6 Join Date: Oct 2016
I wouldn't depend on that. My local Vatozone told me they don't do free check engine light scans anymore.
01-21-2019, 09:20 AM | #5 |
Drives: 2013 2SS Dusk Special Edition Join Date: Jan 2019
Take the engine cover off and make sure a wire didn't come off one of the coil packs. Happened to me and that's all it was. Dealership said "No way would that be the problem, bring it in." I popped off the engine cover and there was the wire just hanging off. Plugged it back into the coil pack for that cylinder and fixed.
2013 Dusk Special Edition 2SS/RS (1 of 205)
LS3, 6-spd w/ Hurst short shifter, navigation, sunroof, Boston Acoustics, and Borla Type-S cat back exhaust. |
01-21-2019, 09:37 AM | #6 |
Instagram: Sangstah
O Reilly's will definitely read your code for you.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-22-2019, 07:48 AM | #7 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
+1 for O'Reilly's, they still do as far as I know.
01-22-2019, 09:02 AM | #8 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Can't speak for all, but know our local AutoZone will check them for free.
01-23-2019, 08:23 AM | #9 |
Drives: 13 Camaro Join Date: Oct 2016
Goodness a cheap code reader like the auto parts store uses is only like $12.
01-23-2019, 08:29 AM | #10 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
You can buy a scanner at Walmart for about $20.
01-23-2019, 09:20 AM | #11 |
When I got in my car to come home from work this morning, the check engine light was out. It starts with the remote starter again. I don’t understand it but, I’m glad that it went out. So I never got to take it somewhere to find out why it was on in the first place. Oh well. Thanks for the information, I didn’t know scanners were so cheap. That’s why I like this forum, you can always get an answer good or not so good lol
01-23-2019, 09:54 AM | #12 | |
Drives: 2010 Camaro SS Join Date: Oct 2013
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
01-23-2019, 01:44 PM | #13 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
When the battery gets older/weaker (or a heavier load from a cold engine/starter), I've had it trip the CEL light numerous times.
Most (if not all) codes are still stored in memory. At least the code readers that I've used can still retrieve them (until the battery is disconnected).
Jack Bilger
01-23-2019, 05:57 PM | #14 |
The remote start will only work 3 times and then you have to start the car with the key. Now the remote will work 3 more times, etc, etc, etc...
Lusinda 2010 2SS/RS |
