12-08-2019, 08:11 AM | #1 |
Drives: 2010 SS L99 Join Date: Sep 2018
BMR motor mounts
Just got these and was wondering if anyone else was running the solid aluminum upgrade and if so, whats it like? I still need to grab a transmission mount from Prothane too.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
12-08-2019, 09:42 AM | #2 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Just ordered some as well, installed the rev shift poly mount and vibration was crazy for the first 300 miles or so but it seems to settle in about 1200 or so.
12-08-2019, 10:04 AM | #3 |
Nice. Hows it feel, more responsive? They were the only true solid mount I've been able to find and I am very excited to get them installed. I saw theres an MTI tranny mount for the manuals as well, but for the 6L80 guys it seems Prothane is the only option, at least from what I could find.
12-08-2019, 10:17 AM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I don’t see a trans mount for a 5th Gen from Prothane.
Orange Krush II
12-08-2019, 10:42 AM | #5 |
8.60 @ 157 @ 4200lbs
Mounts
I run them very nice upgrade
2010 camaro twin turbo 8.60 @ 157 full weight 4200
12-08-2019, 11:09 AM | #6 |
Heres the link on Jegs I have been looking at:
https://www.jegs.com/i/Prothane/311/...iABEgLWEPD_BwE Excellent! Glad to hear this from someone with a dialed-in suspension. Thanks 1fast
12-08-2019, 06:13 PM | #7 | |
12-09-2019, 05:23 AM | #8 |
Wow that’s a nice piece but looks like it might cause a lot of vibration.
Orange Krush II
12-09-2019, 07:44 AM | #9 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Using the Prothane engine mounts and rev shift poly insert...amazing difference in the "feel" of the car..much tighter all around...and have been on the car for 3+ years...
This is the first winter where the NVH is really pronounced until the car has been driven a few miles to warm up. Not that bad but I can't imagine what solid mounts would be like. BTW - the Prothane mounts are extremely robust units and even with the poly mounts the engine twist makes the front right twist up slightly good luck! PEACE
12-09-2019, 08:50 AM | #10 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
So, what exactly is the purpose of upgrading these? Or maybe the better question is, is what point does one need to look at upgrading the motor and trans mounts?
How bad is the installation for motor mounts with the motor in place?
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
12-09-2019, 09:46 AM | #11 |
Less movement and slop in the drivetrain which in turn saves wasted power that would have been absorbed through all the twisting and flexing.
12-09-2019, 02:33 PM | #12 | ||||
I have read about people lifting the motor at the oil pan with a jack and a block of wood, but also bending the pickup tube in the process, or rupturing the pan. This is not what everyone would recommend doing, for obvious reasons, so I may be taking it to GPI for another round of mods, whenever that comes up.
