02-23-2021, 01:49 PM | #1 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Long tubes without cats
Hey guys I'm getting ready to do the exhaust. I'm thinking of buying this kit from Texas Speed https://www.texas-speed.com/p-34-tsp...s-wo2-ext.aspx
but I was also thinking of paying a local shop to do the tuning after I install the kit. Do you guys know how it will run without the rear o2 sensors because I will have to drive it to the shop which is about 20 miles away? Any opinions on this kit?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-23-2021, 02:13 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
You will throw codes but it will drive.
02-23-2021, 02:18 PM | #3 |
Started#gottalovethatblue
You will eventually throw a code with long tube headers un-tuned, but you'll be fine for the drive.
02-23-2021, 02:25 PM | #4 |
Thanks guys. I just realized that Texas Speed is only a 41 minute drive from where I live. That means I won't have to pay for shipping.
02-23-2021, 02:30 PM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
After installing my headers I drove to the exhaust shop to weld it up then had it tuned a week later by dynosteve. It’ll drive fine but don’t abuse it till you get it tuned.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
02-24-2021, 08:25 AM | #6 |
As mentioned above, you will be fine and you will eventually show a code, just take it easy until you get her tuned.
02-24-2021, 08:49 AM | #7 |
Tri-County Camaro SWFL
I drove my car untuned with headers and no cats for a month or 2. Then installed a RCR rodmod intake and drove it 150ish miles to the other coast for a tune. You will be fine.
02-24-2021, 10:54 AM | #8 |
Drives: 2010 SS L99 Join Date: Sep 2018
I drove mine untuned for 2.5 years with catless longtubes and a muffler delete. Yep the O2 sensors were trash by that time, but it drove.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
02-24-2021, 01:29 PM | #9 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I drove mine with long tubes and no cats with no tuning for about a year (other then turning off the cels)
Your not going to hurt anything other then the o2 sensors if you leave them in there. You won't have the full benefit of the long tubes without a tune but its not going to hurt anything. Send it.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
02-24-2021, 02:17 PM | #10 |
Thanks guys
02-24-2021, 03:35 PM | #11 |
That's called extreme desire to enjoy the ride sir!! lol.
02-24-2021, 05:35 PM | #12 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I would recommend on choosing the right exhaust setup. A lot of people like loud, but long term, they end up hating it. You also gotta factor in the drone that the exhaust will generate, because that will wear you down when you’re driving. Buying shit twice costs a lot of money.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-05-2021, 03:33 PM | #13 |
Hey guys I'm thinking twice about not running cats with all the talk about emissions. It's only a couple of hundred dollars more for a full exhaust kit with them than without. But what I'm wondering is can I run all four o2 sensors with high flow cats? Is there any benefit to running all four sensors versus the two?
03-05-2021, 03:37 PM | #14 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
