12-04-2011, 09:30 PM | #1 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
Need help with Pedder's wheel hop
I did a search but I didn't find anything. I have the Pedder's track 2 kit & I am running 315's. I am getting wheel hop in the wet or dry. I have tried it with the t/c on & off it doesn't matter. I think I have the shocks set on click 12. What can I do to fix it?
12-04-2011, 09:41 PM | #2 |
Drives: 5th Gen Rental Join Date: Aug 2007
-do you have an alignment print out?
-when was the last time you did a nut check? lol Nut check meaning that you went through everything and verified that every bolt and nut was tight. Do you have any clunking noises like something is loose? |
12-05-2011, 04:42 PM | #3 |
HT5 COTW 1/21/13
Yes I have a print out, I will find it and post it up here. I haven't done a nut check for awhile. I don't have any clunking noises.
12-05-2011, 05:57 PM | #4 |
10-4 let me know
01-13-2012, 12:20 AM | #5 |
HT5 COTW 1/21/13
Ok I finally got around to getting my paperwork out. I hope this is what you need. Thank you for looking
01-13-2012, 08:41 AM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
I think we found the problem. You have a huge green tire blister on your left rear tire
I do have a few questions. 1. What is your RWHP? 2. When does the wheel hop occur? i.e. Hard launch, hard shifts, at the drag strip... 3. Do you have any drive-line mods? 4. What size are your rims? 5. 315/30/20 tires? |
01-13-2012, 11:47 AM | #7 | |
HT5 COTW 1/21/13
1. I don't know my RWHP. It is all stock with muffler delete. 2. Hard launch, hard shift anytime I break the tires loose. I haven't taken it to the drag strip. It does it in a straight line. When I autocross and slid it around it doesn't do it. 3. No drive-line mods 4. If I remember right they are 20x11 5. 315/35/20 Here is my build http://www.camaro5.com/forums/showthread.php?t=193034 Thank you for helping me out |
01-13-2012, 12:18 PM | #8 |
Nice car!
What are your settings for damping? What are the sway bar set to? Tire pressures? |
01-13-2012, 03:21 PM | #9 |
HT5 COTW 1/21/13
I think I am running them at 10 clicks out and 34psi on the tires. The sway bars I don't, I will have to check that.
01-13-2012, 08:23 PM | #10 |
HT5 COTW 1/21/13
The bolt is in the first hole. The farthest one from the end.
01-13-2012, 08:44 PM | #11 |
As in closest to the rear bumper, would be full hard. Most of what I see from here looks to be right on. Please try this. Set the rear dampers to full hard. Give it a run. Then drop the tire pressure down to 30 pounds and give it another run. We'll go from there.
01-13-2012, 08:51 PM | #12 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
01-13-2012, 09:25 PM | #13 |
El Hefe
Drives: Black Camaro 2SS/RS Join Date: Jul 2010
Its cool that you have someone with great patience and experience to help you with this problem.. good luck.
01-14-2012, 01:04 PM | #14 | |
HT5 COTW 1/21/13
Similar Threads | ||||
Different Wheel Construction Types Explained | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 45 | 12-21-2017 08:37 PM |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices | JDP Motorsports | Suspension / Chassis / Brakes | 115 | 02-16-2015 08:42 PM |
BMR Anti Wheel Hop Kit | MTI Racing Kevin | Suspension / Chassis / Brakes | 3 | 09-23-2013 03:04 AM |
Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 11:50 AM |
