06-16-2015, 08:57 PM | #1 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
Gas Guzzler Tax?
Why do we pay a gas guzzler tax when our ZL1's come with the skip shift BS feature! I really don't understand why. Anyone who can explain this in plain English please!!!
2015 Z/28 #642 Black Bad Ass
06-16-2015, 09:05 PM | #2 |
ZL1Naboz
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC Join Date: Mar 2013
You paid for it it's easy to tune out
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno 559.92 RWHP 519 RWTQ |
06-16-2015, 09:16 PM | #3 |
I'm not sure what you mean, can you explain further?
06-16-2015, 09:25 PM | #4 |
ZL1Naboz
Go to apexspeed.com sponsor on forum and for like $25 you can snap in a CAGS eliminator module into trans harness and eliminates it.
06-16-2015, 09:26 PM | #5 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Because even with skip shift the ZL1 manual does not meet the minimum fuel economy set by the 1978 National Energy Act. Without skip shift the tax would be higher. Automatic owners pay double the tax because of worse fuel economy than the manual.
06-16-2015, 09:35 PM | #6 | |
I will probably put a skip shift eliminator in eventually but up till now, I have not had to much intervention with that feature. I just thought that, why did Chevy put it in the ZL1 manual transmission if it does not provide any benefit to fuel consumption and the gas guzzler tax.
06-16-2015, 09:50 PM | #7 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
You can drive through the skip shift. Just do not shift until the notification goes away.
06-16-2015, 10:16 PM | #8 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Tax Schedule
The IRS collects the tax directly from the manufacturer or importer of the vehicles. The following table shows the gas guzzler tax rates which have been in effect since January 1, 1991. The manufacturer or importer must pay this amount for each vehicle that doesn’t meet the minimum fuel economy level of 22.5 mpg. Combined fuel economy of: Amount at least 22.5 mpg No tax at least 21.5, but less than 22.5 mpg $1000 at least 20.5, but less than 21.5 mpg $1300 at least 19.5, but less than 20.5 mpg $1700 at least 18.5, but less than 19.5 mpg $2100 at least 17.5, but less than 18.5 mpg $2600 at least 16.5, but less than 17.5 mpg $3000 at least 15.5, but less than 16.5 mpg $3700 at least 14.5, but less than 15.5 mpg $4500 at least 13.5, but less than 14.5 mpg $5400 at least 12.5, but less than 13.5 mpg $6400 less than 12.5 mpg $7700
Bryan 2018 ZL1 M6
06-16-2015, 11:57 PM | #9 |
Drives: 2015 ZL1 Join Date: Mar 2015
So if we have a combined fuel economy of 16MPG why do we pay $1300? Not that I'm complaining.
http://www.fueleconomy.gov/feg/bymod...t_Camaro.shtml |
06-17-2015, 09:54 AM | #10 |
Thanks Z06 Bryan, good information!
06-17-2015, 01:32 PM | #11 |
Drives: 2015 2SS, 1LE, Dual Mode, Black Join Date: Aug 2014
The skip shift is BS for sure. Like others have said, the eliminator kits are an easy install. However, your owners manual tells you what the controlling parameters are. The throttle position is kind of low and that's the one I use to get the interlock to go away before you shift as the throttle percentage is pretty low. Yours has a blower so it probably reacts somewhat differently than mine. It's like learning a different driving technique to work around it and every once in a while it catches me, but never on an on-ramp !
06-17-2015, 01:41 PM | #12 | |
Drives: 2013 ZL1 Join Date: Oct 2011
they run separate testing don't try and figure it out just know that each car is tested and give a number. they use the table that Z06 brian posted in. Where people screw up is to try to give the car the number themselves. they try to figure out its rating and then use the table. so in the C7 Z06 example everybody was sure it would get taxed based on the EPA site but the manual did not and the auto did. the skip shift will help the car get a better MPG in this testing so hence you get less tax. on my soap box just rev out first get to 2500 rpm and I don't hink you will every hit it. the only way you will ever activate the skip shift is grandma driving the car. I never disabled it and have never hit. I just rev fist get past the threashold.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
06-17-2015, 01:45 PM | #13 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
or on a non-ZL1 side of things you get an L99 with DoD in an attempt to not pay a tax just to have an automatic and then spend money = to the tax to get rid of it.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
