Old 05-12-2023, 05:08 PM   #1
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
Dyno results! 588.32/515.59
Car has Lingenfelter heads, TSP 3.2 cam (240/252), Texas Speed roller rockers, NW 103mm TB, MSD Atomic AirForce, Kooks 2" headers, no cats, factory NPP exhaust, BTR pushrods (2 sizes), factory CAI.
It made 493.22 and 483.59 before the H/C/TB install
Now it's at 588.32 and 515.59
Picked up 95 horse and 32 ft/lbs.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 05-12-2023, 10:03 PM   #2
CamayroZ
Drives: '15 Z/28
Well done!
Peak HP are at the same rpm or did you raise rpm?
CamayroZ is offline   Reply With Quote
Old 05-13-2023, 06:31 AM   #3
joelster
joelster's Avatar
Originally Posted by CamayroZ View Post
Well done!
It made 493.22 last time at 5790rpm
Now it's 588.32 at 6760rpm
Tq was 483.59 at 5060rpm
Now it's 515.59 at 5000rpm
The curves are basically the same until it hits around 4500, then the new combo wakes it up. Before 4500 the tq and hp are up but only by 5-10.
1979 Y84 Trans Am
1986 IROC-Z
Old 05-13-2023, 07:51 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very nice numbers sir!!
Old 05-13-2023, 11:45 PM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Awesome numbers!
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-14-2023, 12:21 AM   #6
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
nice results, may I ask more about the drivability? is it true that the car is less usable below 3000rpm with the TSP stage 3.2?
void_kp is offline   Reply With Quote
Old 05-14-2023, 07:23 PM   #7
joelster
joelster's Avatar
I've only taken it around for about 5 miles but it seems pretty happy down low. My tuner did 2 tweaks to it down there just for drivability. It's a big cam but not crazy big. BTW his dyno typically reads a tiny bit low. When I first got there I told him I would be super happy with 600 wheel. He looked at me and said "Ain't gonna happen". Apparently he's only had 1 or 2 LS7's crack 600 wheel, and they had huge cams. He said that Z06's typically dyno a little higher than Z/28's do. He said that on his dyno most H/C LS7's make 550-585.
1979 Y84 Trans Am
1986 IROC-Z
Old 05-14-2023, 11:23 PM   #8
void_kp
void_kp's Avatar
thx for the info. Btw I was really enjoying your YT videos for autocross. I plan to start using mine in autocross too. my first event will be on 5/19. I am looking forward for it. any recommendation?
Mine is full stock.
Old 05-15-2023, 06:14 AM   #9
joelster
joelster's Avatar
Mine is full stock.
Hopefully you're on different tires than the factory Pirelli's. I'm assuming you are because they don't last long. Our cars are AMAZING right out of the box. Mine is modified quite a bit but the brakes are 100% stock, and the suspension (shocks, springs, sways) is 100% stock. The only suspension mod I have are Vorshlag camber plates. I ran my car stock for 2 years, then did headers, MSD Atomic intake, and ran that for 3 years. Our cars are very neutral when you really start to push them hard. Take them to 85% and they will be planted to the ground. Go to 90-95% and they will slide a bit, but it's very controllable. They don't do anything that will scare you.
First thing I would buy would be a new driver seat. I run 2 Kirkey containment-type seats, on Planted Technology seat brackets. I ran some aluminum spacers to get the seat where I want it. You can swap out a seat in 5 minutes, they are only held in with 2 bolts in the back. When I ran the factory seats, my left knee would be sore as hell for a few days from pushing up against the door panel to keep me in the seat.
1979 Y84 Trans Am
1986 IROC-Z
Old 05-15-2023, 07:16 AM   #10
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Joelster, I see you are in NY if you don't mind what shop do you use? Congrats on the build.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 05-15-2023, 07:41 PM   #11
void_kp
void_kp's Avatar
thx for the tips. i actually drove on different tires on the road and i have a set o trofeo R on spare rims to go to track/autocross.
I had the chance to push the car to traction limits in corners and i confirm what you said: it’s very communicative and easy to predict
Old 05-16-2023, 06:30 AM   #12
joelster
joelster's Avatar
Frumusa Performance in Rochester. Mike Frumusa is an amazing tuner. I got my most of my parts through Black Label Tuning out of Rhode Island. Mike Verdolotti owns it and has a lot of knowledge about LS's specifically LS7's.
Trofeo R's will not be as fast as a legit tw200 autocross tire. The Trofeo's will put you into classes with guys on Hoosiers since they are treadwear 60 or something like that. The best 19" autocross tire for our cars is the Falken RT660 in 315/30/19. They are about $430 each.
1979 Y84 Trans Am
1986 IROC-Z
Old 05-16-2023, 06:50 AM   #13
Joe.G
Joe.G's Avatar
Rochester is about 5 HRS from me, one day I'll find someone close to me.
SCT X4 Dynosteve,
Old 05-16-2023, 12:24 PM   #14
GeneRoss
GeneRoss's Avatar
Drives: 14 Z/28 #368 02 SS(sold) 2012 Equus
Sounds like you're closer to me.
I have used JTM out in long island. They are pretty good too. I did basic bolt ons and tuning on my old 02 SS, nothing intense. They had a bunch of C6 Z06's getting work done when I was there. There are pretty good reviews for JTM from the Corvetteforum guys on JTM.
2014 Z/28 #368
GeneRoss is offline   Reply With Quote
