06-11-2023, 06:01 PM | #1 |
Drives: Chevrolet Camaro Z28 (2015) Join Date: Feb 2023
oil pressure too high? overfill?
Hi folks,
I guess I've overfilled my 2015 Z/28, after driving to temperature and letting engine cool down for ~30 min, the dipstick reads well above max range (~1 inch more). as for oil pressure reading it seems ok at low revs, but it gets to 6bar if I go around 4500 , maxing out the reading. I suspect this is too much pressure but I was not able to find any specs about the max bar for this engine. Any ideas/help? |
06-11-2023, 06:39 PM | #2 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
There are two drain plugs. Engine takes 10 QTS. When it cold it maxes the bar chart with 5w30, on Ed warmed up it will go up and down with RPM. 10 QTS with filter is spot on.
06-11-2023, 10:20 PM | #3 | |
I realize the mistake, I am waiting for a syringe to be shipped from amazon, I will pull out some |
06-12-2023, 12:58 PM | #4 |
Drives: '15 Z/28 Join Date: Nov 2021
@void_kp, if you have an air compressor, do yourself a favor and buy one of these Mityvac fluid extractors.
One of the best investments in a shop. I have had this one for many years and it has paid dividends extracting various fluids! |
06-12-2023, 03:30 PM | #5 |
Drives: 2015 Z/28 Silver #713 Join Date: Feb 2016
Yes, go back and read your owners manual again on how to check the oil level.
06-12-2023, 09:29 PM | #6 |
06-13-2023, 04:52 AM | #7 |
The highlighted portion states to check oil level 5-10 minutes after warmed engine is shutdown.
06-13-2023, 09:15 AM | #8 |
yes yes, i did that too (10 min) but my problem was just adding a full quart after measuring instead of going with smaller increments. the syringe arrived and i’m going to remove some oil tomorrow. car won’t run until friday
06-14-2023, 06:26 AM | #9 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
6 bar is crazy high. Almost 90lbs of pressure. You sure it has 5w30 in it and not 10w30?
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
06-15-2023, 10:10 AM | #10 |
06-16-2023, 02:00 AM | #11 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Here's a pic for reference. 4th gear, approx 4K RPM. Ambient air temp about 85*F. Mobil One 5w30.
