Old 06-16-2023, 07:33 PM   #1
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
Weighed her today!
3564
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 06-16-2023, 08:51 PM   #2
Gouki
Drives: 2014 Z/28
That's much lighter than mine, what have you done for weight savings ? Do you have the weight distribution F/R.
50% gas.
LF 1000 1042 RF
LR 920 829 RR
Total 3791 lbs
Cross 1962 lbs
51.75%
Gouki is offline   Reply With Quote
Old 06-18-2023, 06:05 AM   #3
joelster
joelster's Avatar
I could have looked at the F/R but I was just wondering about the total weight. My car has just about everything you could do without cutting it up. Biggest weight savings were going to Kirkey seats instead of the heavy Recaro's. It has a ton of stuff removed. The wheels/tires are much lighter, etc. I could get it race ready and under 3500 if I wanted to. It probably has 40 extra lbs of fuel in it.
1979 Y84 Trans Am
1986 IROC-Z
Old 06-18-2023, 06:36 AM   #4
GeneRoss
GeneRoss's Avatar
Drives: 14 Z/28 #368 02 SS(sold) 2012 Equus
What is your rim/tire set up?
2014 Z/28 #368
GeneRoss is offline   Reply With Quote
Old 06-18-2023, 09:48 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What wing are you running???
Orange Krush II
Old 06-19-2023, 06:28 AM   #6
joelster
joelster's Avatar
Apex SM-10 in 18x11, with Yokohama A052's in 315/30/18
Front wheels:
https://www.apexraceparts.com/shop-b...aro-wheel.html
Rear wheels:
It's from a company called Wing-logic, and the upper piece is just a flat piece of aluminum that I mounted. Endplates are custom from 2 flat sheets of carbon fiber. I have an upper wing element on order from 9-lives racing, but from talking to a lot of people, I likely won't see it for 20-30 weeks.
https://wing-logic.com/product/65in-racing-wing/
1979 Y84 Trans Am
1986 IROC-Z
Old 06-19-2023, 07:29 AM   #7
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
Front wheels:
Rear wheels:
I ran across PCI(pro car innovation). Same extruded wing material but looks like they might have in stock selections you can get any length and just make your own mounting setup. Figured I’d pass info along and hope it helps.
SIM GhostrdrZ is offline   Reply With Quote
Old 06-19-2023, 08:36 AM   #8
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Why didn't you go with 12" wide in the rear? They clear the carbon ceramics or are you on a different brake setup? Do you run a spacer? I couldn't get a clear answer from Apex when I was trying to purchase from them a year or two ago.
Coz3z3 is offline   Reply With Quote
