Old 02-18-2012, 07:53 PM   #1
Reppinthe10camaro
Reppinthe10camaro's Avatar
Drives: 2010 Camaro 2LT
Needs pointers on my 2010 V6
Performance wise i I only have the flow master AT's done. Any ideas on x-pipe or resonator delete? What should I order? possibly a CAI? I am open to any ideas that will help to give me a nice sounding V6. The flowmasters have helped a lot but I always want more.
Reppinthe10camaro is offline   Reply With Quote
Old 02-18-2012, 07:56 PM   #2
KMPrenger
KMPrenger's Avatar
Do you want better sound or better performance? These are really two different areas...but they do overlap.
Add some shorty headers to your setup and you'd gain a little performance but have great sound.
Add long tube headers and you'd have a good performance gain but then you'd have to add something to your exhaust setup like a resonated X pipe to calm down the crazy loudness and rasp they long tubes will produce.
As far as performance only, there are lots of things that can be done.
Welcome to the forum man...read on...as times have been great for the Camaro V6 LLT engine as of late....we've found great inexpensive ways to make the car run fantastic.
Old 02-18-2012, 09:07 PM   #3
Reppinthe10camaro
If I do jab shorty headers, would the bbk resonated x pipe make it sound good. Does the resonated x pipe make it quieter?
Old 02-18-2012, 09:08 PM   #4
Reppinthe10camaro
Jba*
Old 02-19-2012, 05:27 PM   #5
KMPrenger
KMPrenger's Avatar
I'm assuming you know the different between a standard X pipe and a resonated X pipe.
A resonated X will quiet it down some...but the positive side is it will also cure most of the rast and lessen the in cabin drown and usually lowers the exhaust note just a bit as well.
If you are thinking of shorty headers...I'd try them first without any other change and drive it for a little while and see what you think. At that point, if you feel you really need to calm down the rasp or the drone...try a resonated X.
I don't know about the BBK X, but the magnaflow's part # is listed in the V6 exhaust sticky thread.
Old 02-19-2012, 05:33 PM   #6
Lgndryhr
Camaro Die-Hard
Lgndryhr's Avatar
Drives: 2010 2SS/RS L99 IOM
Welcome to the V6 forums. I see you live in Memphis. Should check out the local Camaro club (links in my sig below).
As far as performance and sound. As KMPrenger said they are two different things but tend to overlap. The shorty headers don't give as much performance, but don't have rasp like long tubes do. The shorty headers tend to have a deeper tone also. I would recommend for your exhaust setup to first get headers then based on sound either do a resonator delete or put on a resonated x-pipe (BBK or Magnaflow).
The resonated x-pipe does quiet it down some, but also helps control rasp and drone.
Phoenix (click for build thread)
13.282 @ 107.70 (100% Stock)
12.481 @ 110.92 (Current mods as of 5/6/16)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
Lgndryhr is offline   Reply With Quote
Thinking about getting a 2010 V6 Camaro need advise DwDrummer Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 34 09-03-2010 04:14 PM
Nitrous Express Nitrous Kits Available for the 2010 Camaro V6 & V8! Kris@BMCPerformance Forced Induction 5 11-04-2009 09:46 AM
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com Redshift Forced Induction 0 07-16-2009 08:31 AM
