11-05-2018, 12:01 PM | #1 |
Lowering springs questions.
Hey guys thinking of lowering my 2013 1le. I want it to sit low but not too low. Ride as close to stock as possible. Let me know what you guys recommend!
Work hard, play harder
11-05-2018, 12:56 PM | #2 |
Drives: 2010 Red SS Join Date: Feb 2018
Lowering springs
I just lowered my SS 1.4” front and 1.2” back with no issues. I spent a day at the track last week without any problems.
11-05-2018, 04:29 PM | #3 |
Started#gottalovethatblue
I have BMR 1" and while they get a little rough on big bumps it's not bad. Cruising around without bumps feels like stock.
11-05-2018, 08:09 PM | #4 |
Drives: 2013 1ss Join Date: Jul 2012
I have a 13 ss that was lowered by a shop. Make sure the bushings are all clocked which makes a big difference on the ride. I found out by doing it myself after their install and it made a big difference.
11-05-2018, 08:36 PM | #5 |
Drives: '13 SS RS Join Date: Dec 2012
Does alignment do this type of thing?
2013 Camaro SS RS
11-05-2018, 09:00 PM | #6 |
We usually recommend BMR or Eibachs. The Eibachs offer a 1" drop which isn't to aggressive but it's enough to give you a great look.
11-06-2018, 07:43 AM | #7 |
11-06-2018, 08:26 PM | #8 | |
Who does this then? Just picked the car up after lowering it, new wheels, and brakes. 1.25” is pretty low! There’s barely two fingers gap left and it hasn’t set yet. Sent from my iPhone using Tapatalk
2013 Camaro SS RS
11-07-2018, 04:37 PM | #9 | |
Check with the installer and maybe they already did it. It really smoothed out a terrible ride for me. |
11-07-2018, 04:41 PM | #10 |
USA-1
JPSS (Camaro suspension masters) recommend Detroit Speed springs..
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-12-2018, 09:59 AM | #11 |
I went with the Eiback Pro+ kit to get rid of the fender gap. Looks great but the car rides like a lumber wagon
