12-09-2015, 02:40 PM | #1 |
Drives: 2015 1LE Join Date: Dec 2015
iPhone "no music files found"
When I plug in my iPhone into the usb port it starts to charge and connects just fine, it then will "index" and then a window will appear "no music files found" although the music is playing through the speakers and the iPod screen is behind the "no music files found" window. if i touch any button it will revert to "FM".
I guessing i need a software update? 2015 Camaro. Any help is appreciated. Thank You. |
12-17-2015, 12:11 PM | #2 |
nobody?
01-28-2016, 04:14 AM | #3 |
Drives: 2015 Camaro SS 1LE Join Date: Aug 2014
I'm having this same issue literally out of no where. Was working fine in the morning, did not change anything on my phone and now it will show "No music files found" and start playing. However, clicking OK returns to FM radio.
I've rebooted the phone multiple times as well as power cycling the radio. Going to try removing the radio fuse and seeing if that works.
2013 2SS RS
CAI Intake Air Scope BMR Strut Bar Tune |
01-28-2016, 07:57 AM | #4 |
Happens on mine as well the usual problem for me is the iPhone if the music app is open it usually has a problem connecting and throw that no files found , it also happens in my 2010 Range Rover sport but it will say can't connect to device, just open the iPhone and close the music app and it should work just fine
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
01-28-2016, 10:48 AM | #5 |
Drives: 2010 2SS RS GFX Join Date: Jan 2015
Mine sometimes does this, usually hit play on the phone before plugging into the usb socket and it works fine
2010 2SS RS GFX airaid, SP LT Headers, SW retro chambered exhaust & SCT tune
1968 SS RS 408ci, drag car, too many mods to list! |
02-03-2016, 09:38 AM | #6 |
agreed I find that works as well...
09-17-2022, 12:31 AM | #7 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
Resurrection of a long dead thread.
Has anyone found a fix for this? |
09-17-2022, 05:52 AM | #8 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
What in your music file format in iPhone ?
09-17-2022, 09:56 AM | #9 |
