Old 07-27-2015, 02:26 AM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
MT ET Streets S/S or Nitto NT05r
I'm going to be needing new tires in the next several weeks and I'm wanting to get drag radials for the rear then street tire up front. I'm going back and forth from the new Mickey Thompson Street S/S 305/35/20 and the Nitto NT05r 315/35/20. About 95% of the local racers who have drag radials run the older versions of the MT ET Streets, but I like the look and the availability of 315s of the Nitto. What do you guys think? I'm currently at 500rwhp and will be spraying a 150 shot by the end of the year. If I can't hook on a drag radial, I'll buy some 17x10 Welds with a 28x10 Hoosier bias ply slick, but I still need a better rear tire regardless.
Nitto NT05r
MT ET Streets S/S
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 07-27-2015, 06:44 AM   #2
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
The "new" M/T still uses the same compound as the previous tire, they basically changed the tread design to make it a bit more street friendly and some sidewall changes iirc
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 07-27-2015, 06:48 AM   #3
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Not my personal experience, but I was talking to someone who has tried/used both tires. He said the MT are way better than the Nitto...btw where do you guys race up in the NO? I'll have to give you a shout next time I go up there to check out your car.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 07-29-2015, 11:41 AM   #4
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
I have 675 rwhp and cannot hook on the NT05R in the 305/35/19 size. Getting 1.85 to 2.00 60 ft with pressure between 17 psi and 20 psi
When I only had 550 rwhp, I was able to cut 1.7x on the NT05R with 20 psi and even got a 1.66 once.
G8GT4now is offline   Reply With Quote
Old 07-29-2015, 12:05 PM   #5
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Why not the et street r?
Trob85 is offline   Reply With Quote
Old 07-29-2015, 03:52 PM   #6
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
Were the NT05R's consistent at 550rwhp?
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
Old 07-29-2015, 03:55 PM   #7
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
Yes, very consistent.
Old 07-29-2015, 04:57 PM   #8
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I'm trying to decide between these 2 myself. I have NT05's now so getting the R would match up for my front tires but I hear the MT's are better.
MODS:
Old 07-29-2015, 05:45 PM   #9
jake2212
jake2212's Avatar
Drives: none (yet)
mickeys are really good tires, very consistent
jake2212 is offline   Reply With Quote
Old 07-29-2015, 06:56 PM   #10
Josh The People
Josh The People's Avatar
Drives: TT 10' SS -> 16' SS
Dont want to hijack your thread. But im in the same boat looking for some new rear tires with over 500whp. Looking at the exact same tires Was kinda leaning towards the M/T. Is there a big difference in price? Also i still have the stocks up front. Some where some one said that will throw engine codes if i just change the back tires to a 305/35r20? Is this something a tuner can fix?
Josh The People is offline   Reply With Quote
Old 07-30-2015, 01:22 PM   #11
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
Had the Nitto's, now i have the Mickey's S/S Haven't been to the track yet but on the street they hook hard at 28 P.S.I The Nitto couldn't do that .BTW went with 305 35 and they are bigger then the Nitto 315 35
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 07-30-2015, 01:57 PM   #12
familycaronROIDS!
CMS built
familycaronROIDS!'s Avatar
Drives: 13 5.0
Et streets are on another level. Nit to are good for 400rwhp or less...
wrenched & tuned by Cunningham Motorsports
familycaronROIDS! is offline   Reply With Quote
Old 07-30-2015, 02:21 PM   #13
nosmr2
Drives: 2011 L99 SS
Awesome, good to hear.
2011 SS
ADM LSA Conversion
nosmr2 is offline   Reply With Quote
Old 08-05-2015, 09:43 PM   #14
nosmr2
Drives: 2011 L99 SS
Picked up a used pair of the M/T's from a member here. Simply put, they hook up. From a 40 roll, 60 roll and a dig no spinning with 501 to the wheels. Glad I got them.
2011 SS
ADM LSA Conversion
