Old 02-20-2024, 07:59 AM   #1
Celticclark
Celticclark's Avatar
Drives: 2010 CamaroSS 1954Belair 28 Model A
identify part# for EVAP
Hi guys. I have a new to me 2010 SS L99 and I have the dreaded Service Stabilitrack warning. It gives me codes P0452 pressure sensor switch low P0496 high purge flow. I have been trying to figure out a part number for the line that goes into the purge valve which seems to be the fuel line as well (2lines). I have ordered a replacement for the temporary orange line from purge valve to left side of intake. I also want to make sure that the purge valve is oriented correctly.
Thanks for any help!
Celticclark is offline   Reply With Quote
Old 02-20-2024, 08:35 AM   #2
SlowLS1
SlowLS1's Avatar
A couple of things...
Purge valve should be mounted to the head with a steel bracket.
The end with the electrical connection should have the line that comes from the frame rail. This is the smaller of the 2 braided lines. It is the evap line.
The orange line (temp part) should be connected to the other port (opposite of the electrical connection). It is connected to the right place on the manifold.
Google "purge valve camaro5" and go through the image results, you will see how it should be.
Brian
SlowLS1 is offline   Reply With Quote
Old 02-20-2024, 09:18 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Brian
Great info Brian!!
Old 02-20-2024, 09:46 AM   #4
Celticclark
Brian
So it's backwards, well there's a start! Thank you!
Old 02-20-2024, 10:28 AM   #5
SlowLS1
SlowLS1's Avatar
No problem, hope it gets you going the right direction.
Looks like someone has buggered your car a lot before you got it. Don’t hesitate to ask more questions. There are a lot of knowledgeable people here.
Old 02-20-2024, 10:30 AM   #6
SlowLS1
SlowLS1's Avatar
Great info Brian!!
Old 02-21-2024, 07:46 AM   #7
Celticclark
Still looking for part number info.
Old 02-21-2024, 07:51 AM   #8
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Purge Valve to Manifold: GM 12607115
Purge Valve to Return Line: GM 20962845
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 02-21-2024, 11:22 AM   #9
Celticclark
Thanks so much!!!!
Old 02-24-2024, 10:16 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Good job brother!!
Old 02-26-2024, 08:03 AM   #11
NoDakZ/28
NoDakZ/28's Avatar
Originally Posted by Celticclark View Post
Thanks so much!!!!
Good job brother!!
Happy to help!
2014 1LE - Sold
