04-21-2016, 07:02 AM | #1 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
T5 Splitter Install: Would rather not use the supplied rivits!
I'm in the process of painting my splitter and when I install it I would like to use something a little easier to remove later (if necessary), other than the supplied rivets. I've searched the threads and didn't find any info. Yes, the rivets could be drilled out but might as well find an alternative now. What have you used that doesn't involve nuts and bolts as it would be a bit tight getting to the backside. Thanks!
04-21-2016, 07:12 AM | #2 | |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
http://acscomposite.com/collections/...-lt-rs-only-v6
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
04-21-2016, 07:56 AM | #3 |
Yes, it is the ACS and it did come with rivets!
04-21-2016, 08:45 AM | #4 |
INJACC
I looked on their site and it shows snap on clips,,,sorry for the mix up
04-21-2016, 12:30 PM | #5 |
No problem. I bought it from southerncarparts.com (only $35 shipping). I wonder if the snap in clips weren't holding up well.
04-21-2016, 12:42 PM | #6 |
I just hung up with ACS. They went to the rivets as many, (some), people weren't drilling the correct size holes and the plastic inserts, (scrivets) were failing. He recommended using M8 x 20 bolts and nut instead of the rivets but not to use the scrivets (as he called them). It's be more secure that way. I'll just have to see just how tight it is to get my hand under the lip to tighten the nuts.
04-21-2016, 01:18 PM | #7 |
Drives: 2010 Summit White 2SS Join Date: Mar 2011
http://www.quik-latch.com/
could always go this route, very easy to install and would be a breeze to take on and off we use these on alot of different things on our race cars
04-21-2016, 01:27 PM | #8 |
Drives: 2014 2SS/RS Join Date: Jun 2013
You should have gone for the "track pack" to get the metal bolts, nuts, and washers.
Go to home depot and get your own bolts, nuts, and washers. Also get additional rivets and a pop rivet gun |
04-21-2016, 01:31 PM | #9 |
Oh, if your rivets are plastic, spring for the metal ones. Home depot, 3 bucks.
04-21-2016, 03:22 PM | #10 |
Drives: 2011 2SS w/RS PKG Join Date: Sep 2010
I have the T4 splitter and had rivets with the kit as well. I just went ahead and used 5/16th screwvits. Been holding up nicely after 500 miles @75mph + highway and spirited driving.
04-21-2016, 05:39 PM | #11 |
INFECTED
Drives: 2011 1LT Synergy Green Join Date: May 2011
I used nuts ,bolts & washers. Put it on in 30 min.been on for two years and still perfect.. It was a little tight reaching my hand in through the front lower grill to tighten the bolts . But it can be done. Good luck.
04-21-2016, 07:08 PM | #12 |
Thanks all. I'll try the screw and nut route!
04-21-2016, 07:48 PM | #13 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I have the T4 splitter, bought it in August. Mine came with two plastic rivets to use in the corners, but the rest was nuts and bolts.
I'll probably be removing it to repaint it this summer. When I do I'm going to modify the holes I drilled to use speed nuts. That way removal for the occasional repaint will the simple. I'm 6'-4" and have big hands. Some of those suckers are hard to get to. Something like this:
04-21-2016, 08:07 PM | #14 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
T5 here, nuts and bolts, solid as a rock.
Tags |
acs t-5, splitter, splitter install |
