11-30-2012, 06:34 PM | #505 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Just got mine today from Maureen too! I'm not sure yet where I'm gonna have them installed or if I'm going with an Eaton posi or not! I have all winter so no hurry! Also doing the bushings while I'm at it!
12-03-2012, 10:21 AM | #506 |
Drives: 2010 ABM SS #14 of 2,027 Join Date: Jan 2007
No parts found with that search number
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840 |
12-05-2012, 11:45 AM | #507 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
so real quick...axles and hubs off a 1LE into a SS diff for around $750...and are we a 'known fact' these are good to 650hp?...doesn't GM give torque ratings on drivetrain parts?
-John S.
12-05-2012, 03:52 PM | #508 |
chevy pride
i bought the axels and hubs , and had them in they do fit but u need to order axel nuts aswell. ur stock ones wont fit. i gonna put them in tonight i got it all here and rdy for round 2 install with phaft trailin arms and bushings. going to the track on the 15 if clear. so we will see if they with stand 600 rwhp and around 700 rwtq. im at 460 ish rwhp. and a 150 shot. but im gonna be bring in the nitrous on a ramp so its not a sudden hit.
check out ky speeds fb page https://www.facebook.com/kyspeed |
12-09-2012, 01:44 PM | #509 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I talked with the parts specialist at John Elway Chevrolet in Englewood, CO. He says they have 3 sets of the 1LE 3.91 gears in stock on the shelf... For those tired of waiting in line. I'm debating picking up a set...
12-09-2012, 03:16 PM | #510 |
Drives: 2SS/RS M6 Join Date: Apr 2008
I just finished doing the 3.91 install today. I did all the work except setting up the gears myself. It took about 6 hours in all. I did it on jack stands in my driveway. Dropping the diff and pulling the axles out is an easy job and anyone thinking of doing the job like I did should go for it. As long as you have the tools and the ability to turn a wrench, it's and easy job. All in all, it cost me $750 and 6 hours of my (and about 2 of a friend) time. The worst part of the job had to be getting the stock diff bushings out. A sawzall will work but that shit sucks fat ones! I'd invest in a removal kit if I had to do it again. For less then members like caverman paid for their gears, I've got the whole job. This break in is gonna be the hardest part after those shitty bushings!
12-20-2012, 01:04 PM | #511 |
Hmm... So assuming I order 22806794 and get the whole pumpkin is there anything else I would need? New bolts? I'm assuming it would be dry and need gear oil. Does anything need to be cannibalized from the old diff or do the old axels just slid into the new one?
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
12-20-2012, 03:54 PM | #512 |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
You shouldn't need new hardware for anything. Just make sure to put some blue locktite on when you put it back together. Old axles should slide in.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
12-20-2012, 04:42 PM | #513 |
Nice!
12-21-2012, 04:05 AM | #514 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Where did you get that 650hp rating from?
2010 Camaro SS LS3 - No Modz
12-22-2012, 08:22 AM | #515 |
instigator
posted here...which means its not a GM spec. they use torque ratings if in manual at all.
-John S.
12-23-2012, 04:40 PM | #516 |
chevy pride
i got the axels ,axel nuts , hubs installedin my ss, took it to the track , i launched it at 2800 rpm , im at 470/430 and they held so far, i tried sprayin it but the clutch slipped so , next year ill get to test them a lil more
12-23-2012, 05:43 PM | #517 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Anyone know if the front ZL1/1LE hubs fit the SS? Since I track figured it's a matter of time before the SS hubs fail. My right rear started making noise before I had to put it away. I'll have the new rears next week.
01-14-2013, 11:40 AM | #518 |
Drives: 2017 HBM A10 ZL1 Join Date: Feb 2011
Has anyone installed the 3.91 gears on a truetrac? I don't see any reason why it wouldn't fit but trying to be sure before I order the truetrac.
The documentation I can find on the truetrac only lists the 3.27 and 3.45 gears.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better. |
