02-12-2023, 07:22 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
What Amp/Harness and how to for a 14 SS? Amp before speakers?
I am slowly going to upgrade my system, i am not looking to go all out but would like better sound. I think at this point I would like to keep my stock speakers and start with the amp. I like my head unit and don't plan to replace it.
Can I get a plug and play amp set up? I have googled it but everything I am reading gets off course, I would like an amp that will work with stock and future aftermarket speakers. Thank you
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
02-12-2023, 07:52 AM | #2 |
Drives: 2011 Camaro ss Join Date: Sep 2021
If you have the Boston Acoustics sound system in camaro it’s pretty easy, they make a plug and play harness to add an amp. They also have precut boards for you to mount an amp in the BA amp location to hide your amp. I went with sound ordnance for my amp for components, loud enough for me.
2011 Camaro 2SS Victory Red
Rotofab CAI, 160 Thermostat, Stainless Works Headers, Livernois Motorsports Thunderstorm Exhaust, GPI SS1, rodmod intake, ported tb by GPI, Remote Tune by GPI, Elite Engineering Catch Can, Rotofab washer relocation, JRE scoop, JRE Trans dipstick, BMR Toe Rods, BMR Trailing Arms, BMR subframe connectors, Polyurethane diff bushing and rear cradle mount's, RSM front crash bar |
02-12-2023, 08:06 AM | #3 |
Is it possible that you guys can post links so I make sure to get the correct items.
02-12-2023, 11:06 AM | #4 |
I tired pming you the company but it keeps getting stared out. Google search FARK for camaro and it should come up, the board / amp mount is also from the same vendor you have to look around on their site for it because it is not obvious
02-12-2023, 04:07 PM | #5 |
Is there any amp recommendations that are safe to use with factory BA Speakers and also for a good set of aftermarkets if I switch down the road?
I want a 4 channel amp? On the sight for the adapter it says I loose my center speaker? Is this something that will be noticed? When changing speakers down the road do I not replace the center speaker ( I am assuming that even aftermarkets won't work ) Thanks
02-12-2023, 05:22 PM | #6 | |
02-12-2023, 07:06 PM | #7 |
I don't care for the look of any of the aftermarket head unit setups that iv seen.
02-18-2023, 05:56 PM | #8 |
What are some good AMP Choices these days?
02-19-2023, 08:11 AM | #9 |
Drives: 2011 2SS/RS Join Date: Feb 2016
depends on what you want. Personally,:
Morel, Mosconi, Helix, Brax, JL, Alpine R line (S is ok just cheap now) Avoid: Dual, Blaupunkt, Jensen, Rockwood etc cheap POS. Williston audio labs on youtube is good at reviewing new and old stuff
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
02-19-2023, 08:46 AM | #10 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I have the alpine pdx v5 5 channel amp. Small enough to fit in the factory amp space. Plus it has the extra channel just incase you want to add a sub later on.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
02-19-2023, 09:25 AM | #11 |
I think i have one of those still too... i dont recall. but great option.
02-19-2023, 09:34 AM | #12 |
I have a PDX-V9 id let go of. its not mint but its fully functional and plenty of oomph for most.
02-19-2023, 09:50 AM | #13 |
The v9 is a great choice too. Just way out of my price point when new.
02-19-2023, 09:58 AM | #14 |
Shes not new at all lol. It was taken in on trade when i removed it from a client's car. They went to Helix and now i own those same helix. This V9 i can let go of.
