02-28-2020, 02:42 PM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Racing Seat?
What are you guys running for seats? I'm looking for something that is known to fit the Gen 5 camaro for under $400 that doesn't compromise safety.
And I'd like to retain the stock seat belt.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-28-2020, 03:39 PM | #2 |
You want safety while racing with the stock seat belts but feel better about it by buying a “race seat”.
You’ll need a 5 point belt harness with better mounting points. Depending on the racing, a roll cage to meet the need and then a race seat. But you didn’t mention what kind of racing so the correct folks can chime in. |
02-28-2020, 04:31 PM | #3 | |
So 5 point harness it is. Does anyone make a brace that sits behind the driver shoulder height to mount the harness that is bolt in? I can weld, but it aint pretty. I dont need a roll cage until 9.99 at my track. And I can't 60' yet. Just wanna go have some fun and be safe.
02-28-2020, 04:46 PM | #4 |
Brey Krause has a bolt in that may or may not suffice for drag racing. I know many road racers get it to hold the shoulder harness in a 5 point. I’ve got one in my Z28 but I’m not drag racing. You might need a more serious actually roll cage but not sure of the rules and when that’s needed.
02-28-2020, 05:26 PM | #5 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Tried sending this in our PM thread but wouldn't let me.
What else can I do to my Camaro?
02-28-2020, 06:07 PM | #6 |
Damn, those seats actually look good too.
02-28-2020, 06:11 PM | #7 |
Yea thats badass. Looks like Redline's old shop. I think I can make the stock seat belt work. I have both from the backseat, that do interlock. If I move them to the front and If I can trick the airbag/harness problem, the seatbelt will lock up when needed. It's free, I will try.
I do plan on getting a harness and bar built or installed, but need to drive the car around before I get to racing. So calm down safety nuts.
02-28-2020, 06:33 PM | #8 | |
BOHIC
02-29-2020, 02:16 PM | #9 |
My car is a rebuilt title. Front end collision. The steering wheel was replaced. So i assume the airbag when off. While gutting the interior, i found that my wiring to the drivers seat belt has been cut and taped off.
Will that stop the seatbelt from holding me in an accident? Wtf?
02-29-2020, 02:18 PM | #10 |
There is a resistor in place
02-29-2020, 03:08 PM | #11 |
Wow, WTF is right.
You would assume they replaced the belt assembly if it fired so why wouldn't they just reconnect it properly? Have you inspected the belt? Nice find.
02-29-2020, 05:07 PM | #12 |
BOHIC
Wow... What kind of wheel do you have now? If oem, is it the circle airbag one or the weird shaped one?
02-29-2020, 10:03 PM | #13 |
If the resistor was found on one of your seats, I bet there is a good chance that someone modified the seat wiring for aftermarket racing seats because that’s typically what you need to do when swapping to aftermarket race seats to trick the airbag system. Most likely was done by a prior owner who raced the car at some point.
Car mods: never enough!
03-01-2020, 01:33 AM | #14 | |
Drives: 2011 RJT 2SS Join Date: Jul 2017
