04-14-2017, 02:29 AM | #1 |
Drives: 2010 Camaro RS Inferno Orange Join Date: May 2015
Bank 1 O2 sensor location
What is the exact location for Bank 1 02 Sensor on a 2010 camaro RS V6 Manual Transmission? I have seen conflicting things online. I believe it is the drivers side but have seen images that say otherwise. Please someone let me know.
“The inside of the old Camaro smelled like asphalt and desire, gasoline and dreams.” |
04-21-2017, 03:47 PM | #2 |
Bump
04-21-2017, 03:55 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I know bank one is on drivers side of the v8 and I believe it's the same for v6. Someone with more knowledge will chime in I'm sure. It's also the o2 sensor before the cats, between the manifold and converter. You also have one post cat. There are 2 o2 sensors on each bank.
04-21-2017, 04:09 PM | #4 |
Yes i know there is your upstream and downstream but just wanted to make sure i knew which side bank one was on.
04-21-2017, 05:52 PM | #5 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
bank 1 is passangers side on the V6
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
04-21-2017, 06:43 PM | #6 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
04-21-2017, 06:59 PM | #7 |
Glad you didn't listen to me. Lol thanks to those in the know. Love this site.
04-21-2017, 08:40 PM | #8 | |
[COTW 4/13/15]
before coming across this forum, I thought the same.
04-21-2017, 09:01 PM | #9 |
Really??? You gotta be kidding me. Well that just screwed me up. I for sure thought it was the drivers side.
04-22-2017, 05:55 PM | #10 |
Drives: Classy Join Date: Apr 2017
See the attached
06-02-2017, 03:29 PM | #11 |
Drives: 2010 Black 1LS, 2013 Victory CC BK Join Date: May 2010
Here is the diagram im seeing from autozone. Not sure if its correct to the camaro though as my car is currently thowing the 7e8 cat code which I think is Bank 1 sensor 3.
But then I found this one as well. 1 - B52F Heated Oxygen Sensor Bank 2 Sensor 2 (LLT) 2 - B52E Heated Oxygen Sensor Bank 2 Sensor 1 (LLT) 3 - B52C Heated Oxygen Sensor Bank 1 Sensor 1 (LLT) 4 - B52D Heated Oxygen Sensor Bank 1 Sensor 2 (LLT) Last edited by Runinwithscisrs; 06-02-2017 at 03:45 PM. |
06-02-2017, 05:45 PM | #12 |
Dok
Drives: 2015 Camaro 1LS M6 Join Date: Apr 2016
Unplug one, it'll throw a code and you'll know which side it is. You should be able to get to the connector from the engine bay. Good reason to get a code scanner if you don't already have one. I have a bluetooth one that connects to a phone app.
01-23-2019, 08:10 PM | #13 | |
Drives: 2010 camaro Join Date: Jan 2019
01-26-2019, 10:42 AM | #14 |
No, I just posted the picture to define bank 1 vs bank 2
