06-16-2018, 11:01 AM | #1 |
PhaSSt
Drives: 2011 Camaro SS Join Date: Jul 2017
Lifters Opinion
I just installed my NightFury Cam, BTR Chromoly Pushrods & BTR Platinum Spring Kit but before I put everything back together I decided I might as well get new lifters just to have the extra insurance. I’ve been deciding on Johnson or Comp Cams Lifters but not too sure what to go with. Opinions & link site for your lifters opinion so I can check them out please, thank you!
2011 Camaro SS | Cat-Back Borla ATAK | Roto-Fab CAI | Night Fury Cam | Kooks 1 7/8 x 3" Headers
06-16-2018, 11:13 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Johnson shot lifters ftw
Sent from my SM-N950U using Tapatalk |
06-16-2018, 11:14 AM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Johnson for sure. May want to call them to find out what lifter to get.
06-16-2018, 11:44 AM | #4 |
Drives: 14 ss camaro summit white Join Date: Oct 2014
Everyone recommending me the 2116 on the johnson lifter for my swap
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe 2019 sierra duramax 2500 all terrain x 2001 trans am Lsx 408 ci rebuild in progress(dead project) 1967 camaro Sbc 327. |
06-26-2018, 12:07 AM | #5 |
Drives: 2012 ls3 Join Date: Feb 2014
At the shop I went to said go with a LS7 lifter. And I have the BTR pushrods and springs as well
06-26-2018, 01:57 AM | #6 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Replaced mine with factory lifters when I did my heads/cam swap. Zero issues, and on a different cam now.
06-26-2018, 02:57 AM | #7 |
All Ive ever ran are GM
06-26-2018, 08:25 AM | #8 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
When I did my cam/heads swap, I just put in a new set of GM LS3/LS7 lifters.
They are (relatively) inexpensive, and probably work just fine for 99% of applications. Looked at other brands for about 30 seconds before deciding the difference in money was better spent elsewhere.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
06-26-2018, 09:53 AM | #9 |
Drives: 2010 Camaro SS Join Date: Jan 2017
Gm performance LS7 lifters FTW. Half the price of others and just a reliable. I've seen these spun to 7500 plus on a daily basis
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
06-26-2018, 10:00 AM | #10 |
Johnson shot lifts isnt high at all
06-26-2018, 11:00 AM | #11 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
We often use GM racing lifter, part # 88958689. More expensive but worth it.
06-30-2018, 11:08 PM | #12 | |
Tested to 8k rpm. I didn't even know these were an option.
06-30-2018, 11:44 PM | #13 |
'It's an experiment'
I went with Johnson on my stroker build this time. Used the GMPP LS7s on my last L99 CAM...
-Don
747 RWHP 794 RWTQ
07-01-2018, 09:59 AM | #14 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
I have been thinking of going with the GM racing lifter as well, i hear alot of good things. All i need it some new valve springs seats seals and locks, along with the lifters and my heads are fully built. I went with ZZP for my pushrods, and trunion upgrade kit which was installed when i did my cam.
