06-22-2018, 04:46 PM | #1 |
Drives: 2014 2LT RS Join Date: Jan 2016
2010-2015 factory amplifier replacement kit (FARK) with NVX 4 channel amp
-4 channel NVX amplifier. 125 watta RMS at 4 ohm and 200 at 2 ohms.
-Factory amplifier replacement kit (FARK) made by sub thump to make it plug and play. (BOSTON ACOUSTICS COMPATIBLE ONLY) -Amp is mounted on the sub thump factory fit mount, this allows the amp to fit where the factory amp was. -Includes the 4 gauge NVX wiring as shown which was the perfect length for my Camaro, NVX RCA cables and speaker mounts for the front doors. $300 OBO I pulled this out and left everything hooked up, so this is everything you need to replace the factory amp with an aftermarket one. I traded the Camaro in and pulled all my audio equipment out. Worked great and sounded awesome. First used the factory speakers and improved the sound. Replaced the door speakers with Image Dynamics speakers later on. Last edited by chevyderek72; 06-22-2018 at 05:55 PM. |
07-14-2018, 10:02 PM | #2 |
SOLD!!!!!
