01-24-2013, 11:11 PM | #1 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
Inside wheel well modification. Odd offset.
What is that plastic liner on the inside of the wheel well called? (Toward the center of the car not the part surrounding the diameter of the wheel.)
Is there some way to modify that so my wheel does not rub it or should I get a spacer?? Anything wrong with running a spacer in a drap application? If I get a spacer do I need different (deeper?) lugs? Thanks all. It's sad but I know more about engines than wheels.. lol. Last edited by K32 Camaro; 01-25-2013 at 11:50 AM. |
01-24-2013, 11:55 PM | #2 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
Wild guess u got a vette offset...53 ISh mm? Spacer and suv studs...cheaper way.
-John S.
01-25-2013, 12:23 AM | #3 |
V8 lounge member #5
01-25-2013, 03:00 AM | #4 |
V8 lounge member #5
Just doing an estimate from memory of it's mesurments. I think the offset is +64 ish.
I had the backspacing widened by 2"s and have no way of making it more concave w/o killing the looks. |
01-25-2013, 02:08 PM | #5 |
V8 lounge member #5
ttt
Still wondering about the inside wheel well modification possibilities. |
01-25-2013, 02:32 PM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
That plastic part is called the frnderwell liner, and behind it is the frame supports for the car. Short of doing a mini tub there is no way to increase the space back there.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
