08-14-2015, 01:29 PM | #1 |
Band clamps
I need some exhaust band clamps and idea on some good ones?
08-14-2015, 01:39 PM | #2 |
One time... at band clamp
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
08-14-2015, 02:21 PM | #3 |
Drives: 2014 CRT LT Join Date: Jul 2015
This can go wrong very fast..
08-14-2015, 02:35 PM | #4 |
xquest91x
Drives: 2012 45th Anniversary 2SS/RS Join Date: Mar 2013
Auto parts place sell them... Auto Zone, Pep Boys, O'Reilys, etc
2012 45th Camaro 2SS/RS LS3
Driver Mod: Stage 5 Full Bolt-ons + Tune •418RWHP/420RWTQ• H/C + Bolt-ons + Tune •485RWHP/435RWTQ• Full BMR Stage 2&3 Suspension 3.91 1LE Gear Diff Swap MGW Short Throw Shifter |
08-14-2015, 02:39 PM | #5 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
08-14-2015, 02:40 PM | #6 |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
08-14-2015, 11:15 PM | #7 |
the ones at the autoparts store are probably junk and will rust. You need Stainless steel. Summit has them
08-14-2015, 11:35 PM | #8 |
BUMBL Z
Speaking from experience, if you can have it welded, do it
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
08-15-2015, 11:56 AM | #9 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Yeah weld it if possible. Otherwise the band clamps that auto stores have will probably be those junky u-bolt clamps and they work until you get quality band clamps. Check Amazon for some good ones
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
08-15-2015, 12:17 PM | #10 |
Ok thanks for the info
