05-29-2020, 10:53 AM | #1 |
Drives: 2010 SS Join Date: Apr 2020
Front Door speaker wiring
Hello all...about to undertake the entire stereo upgrade process. Can anyone please tell me the easiest way to upgrade/run new speaker wires to the front doors?
Thanks!! |
05-29-2020, 01:55 PM | #2 |
You won't need to upgrade the wiring for better or more wattage speakers.
It's not the same as wiring power to an amplifier, needing larger gauge wire for power and ground. It doesn't necessarily work that way for speaker leads. If you do, you need to go through that bulkhead connector, and it won't be easy. I find a spot or two that does not have pins, and I will router them out with a drill bit or small flat screwdriver. Then I can pass wires through. You will need silicone spray to get them through the boot, into the door. It can be done, it's just time consuming. |
05-29-2020, 08:57 PM | #3 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i put the crossovers behind the door panel and just ran new wires from there,about 6 feet 1 to the new tweeter 1 to the mid/woofer. i tied my 150 watt RMS old school rockford fosgate into the factory speaker wires at the stock amp.worked like a champ.normally the factory wire is best it is already there and routed so it don't pick up noise.i also use these products. all can be had on amazon or if you buy you speakers on crutchfield they give you everything with the speakers except for the boom mat the b-mat keeps your new speakers from getting wet when it rains i have used them for years and in quite a few installs.
https://www.scosche.com/car-audio/in...-adatpers-6744 https://www.designengineering.com/speaker-baffles/ https://www.sonicelectronix.com/item...a-72-4572.html |
05-30-2020, 06:49 AM | #4 | |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
05-30-2020, 03:23 PM | #5 |
MADE IN THE USA!!!! congrats you have 2 bullet proof amps there.
i have the bd1000 in the pic and the first year power bd1000a1 "batman style" 20 years an it still works great. lets see a china made 1k amp stand up to that!!! |
05-31-2020, 12:33 PM | #6 |
Thank you all for the help!!
06-09-2020, 01:57 AM | #7 |
Drives: 2013 BRM ZL1 Camaro M6 Join Date: Feb 2014
Fitted front and rear with mid-range, tweeters and cross-overs, and ran heavy OFC cable to everything but the tweeters. Removed doors, drilled holes in A-pillar and door to fit rubber door jamb boots (not easy to find) as in photo.
