06-19-2010, 07:23 AM | #1 |
Proud Dad of 3 Kids
Drives: 2SS/RS SIM w/Red Stripes, Opt Fangs Join Date: Jan 2009
Shifter problems when cold
I drive my 2010 ss/rs all year round. When cold, I have to either use hard pressure, or Finesse to shift through the gears. Sometimes it'll pop out of gear or feel like your mashing parts inside the tranny while shifting. Once warmed up good, no problem. You can shift to and fro just like normal. Looking for insight or advice.
Matthew
Living Life |
06-19-2010, 08:17 AM | #2 |
Have you changed the trans fluid? how many miles on it?
06-19-2010, 10:13 AM | #3 |
Proud Dad of 3 Kids
Nope
9,500 miles. I have an appointment at the Chevy dealer Monday morning. It would be nice to have more information from others?
Matthew
Living Life |
06-19-2010, 12:03 PM | #4 |
Drives: Chevy Cobalt SS Supercharged Join Date: Mar 2010
This is a GM performance car thing. They all do it, or atleast all of them I've driven. I think it's the fluid used in the transmission.
06-19-2010, 01:14 PM | #5 |
Proud Dad of 3 Kids
Maybe
Well, the problem is getting worse and has caused me to grind several gears by not forking the desired gear along the shaft properly.
Matthew
Living Life |
06-19-2010, 01:17 PM | #6 |
Doubt the GM performance answer, I've got over 4k on my M6 and no problems. My guess is either a faulty trans or need to fluid swap.
06-19-2010, 03:51 PM | #7 |
Proud Dad of 3 Kids
I'll let you know Monday
We'll see what the dealer says as well. Remember, this thing shifts perfect once the car is good and warmed up.
Matthew
Living Life |
06-19-2010, 04:50 PM | #8 |
Drives: 2010 2SS/RS LS3-M6 Join Date: Nov 2009
I have the same issue, but i have noticed even fully warmed up 2nd and 3rd gear are not perfect, there can be a slight resistance or grind going into 3rd. I think it's a bad syncro and when the trans fluid is cold, it makes it worse since the syncro wont spin as freely due to the viscosity of the cold fluid. I've been trying to get my dealer to replace the synro but no luck so far, they try to give me the BS that a slight grind is normal, which is bull because this is the first manual trans I've ever had that has done it. Hopefully your dealer is better than mine.
Currently:
2010 CGM 2SS/RS GFX LS3-M6, 3.91 1LE diff, Kooks LTH w/ cats, Borla Touring axel back, CAI intake with race scoop, and custom dyno tune Previously: 2010 IBM 2SS LS3-M6 CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune |
06-21-2010, 03:51 AM | #9 | |
Drives: 2010 Camaro 2SS/RS M6 Join Date: Dec 2009
06-21-2010, 05:33 PM | #10 |
Proud Dad of 3 Kids
Just left the Dealer
Dealer had the car all day and said they could not reproduce the concerns I had with the cold shifting (I knew that was coming). On the way home the shifing sequence sure seemed smoother and unobstructed. I can live with that.....for now. I love the car (my 8th Camaro to date).
Matthew
Living Life |
06-21-2010, 07:21 PM | #11 |
Drives: 04 sentra, 2ss Join Date: Apr 2009
i think there might be a tsb on the throw out bearing.
thats what i think i over heard at the dealer when they replaced mine. im going back friday so they can bleed the clutch/brake fluid its really black and dirty around the rim. I was wondering that this might cause the shifter to sometimes get stuck in gear even when the clutch is fully depressed. good luck joey |
06-21-2010, 07:26 PM | #12 |
Redemption
Drives: . Join Date: Feb 2010
Similar Threads | ||||
1st and 2nd gear problems. 1SS 6M | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 10-29-2019 12:22 PM |
Fastlane Pipeline Cold Air Intake at Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 2 | 03-30-2016 07:19 AM |
DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 10:08 AM |
LMR CAI vs Cold Air Induction Inc TEST with RESULTS!! | Late Model Racecraft | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 64 | 01-13-2010 02:33 AM |
MTI Racings new 2010 Camaro short shifter | MTI Racing | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 24 | 08-23-2009 08:07 PM |
