03-26-2018, 08:51 PM | #1 |
15 ss/1le with a e force
my camaro's motor is stock except for the e force supercharger, i am gonna put long tube headers, tune and possibly a ported throttle body on it. anybody done these mods? wondering how much hp you picked up from the headers and tune? do you think the throttle body is worth doing? thanks
also i have read were the fuel rails get input from 1 side and has a line that raps around the front to feed the other side. is this true and if it is does it need to be upgraded so both rails are feed independently or is this just a come on to sell rails? Last edited by drago; 03-26-2018 at 10:27 PM. |
03-26-2018, 10:37 PM | #2 |
Drives: Camaro Join Date: Oct 2015
Yeah you need a zl1 pump and module and some bigger injectors with the fuel rail mod. THEN you can do headers, th, more importantly a smaller pulley. My car for a street car on Invo's is pretty stupid.
2011 IOM RS/2SS. Manual, Eforce, Fuel mods, 3.25 pulley, Stainless Power headers, Borla exhaust, MGW shifter, Z28 suspension with stock front sway, ZL1 Brakes, ZL1 body kit and hood, rotofab
03-26-2018, 11:27 PM | #3 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Fuel control is fine with existing rails. Injectors, ZL1 pump,module, and BAP should cover you to 700RWHP. I’m pushing more with Fore system and still run stock rails fuel pressure is solid.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-28-2018, 09:44 AM | #4 |
Former EForce owner. Fuel Pressure was good here and with the Fuel Rail Mod until #7 let go along with the Rest of the SBE Motor. It was fun while it lasted
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
03-29-2018, 03:09 PM | #5 |
Is that a stock piston? What is the whole story on that? Just for the sake of information sharing. I`m curious.
03-29-2018, 03:46 PM | #6 |
Drives: 2011 Camaro 2SS Join Date: May 2016
What other mods did you have included with this?
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
03-29-2018, 04:08 PM | #7 |
@LS.ACE
Drives: 2014 Chevy Camaro 2SS/1LE Join Date: Jan 2017
Your car already has the zl1 fuel pump. So every time it is suggested just look towards the fpcm and BAP. You already have the pump everyone speaks of. That way you don't buy something you already have.
03-29-2018, 04:45 PM | #8 |
Yes SBE. Cammed BAP Fuel Rail Mod. 650’sRW Cold Day ( for FL) Hit the Gas. No warning. At app 4000 rpm it Grenaded. Found Shrapnel on the Sides of Road Weeks later. It already had Supercharger on it when took it in for TopEnd. Tuner Baselined before Cam Install and mentioned original Tune didn’t look great. After Install ran great without any issues for quite awhile before letting go. Who knows it may have been weakened earlier after EForce Install and Retune at different Shop,Bad Fuel,Pump Failure( FP and OP looked fine), Aliens. All it Took was a little too much Boost, a weakened Rod/Piston and Boom
