05-06-2018, 08:08 AM | #1 |
2011 Camaro SS drivetrain slack?
Hey all. Just picked up a beautiful 2011 Camaro SS 2SS with 11k miles last week. Noticed when taking off from first I get a loud knocking noise while coming off the clutch. While accelerating to 2nd and some of 3rd gear it will continue. Also its pretty bad when skip shifting 1st to 4th. I get no vibrations just loud clunking noise. Is this true? And are there any recalls or extended warrenty for this? I have been looking around and people say it's just normal M6 drivetrain noise. I just want to confirm before taking it to the dealership to get it looked at.
Thank you |
05-06-2018, 05:36 PM | #2 | |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
If its safe and possible try and get a video or recording of it.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
05-06-2018, 07:01 PM | #3 |
05-07-2018, 11:21 AM | #4 |
Drives: 2013 2SS M6 Join Date: Mar 2018
Our cars do have a bit of drivetrain chatter that can be heard if you press the clutch quickly while driving slowly and shifting from 1st to 2nd. What you're describing is not that and doesn't sound normal.
As for the skip shift making it worse, it has a tendency to make just about everything worse. Your options are take off more aggressively at every light, overrev the crap out of your engine in 1st, or lug it going into 4th at 15 mph. A $15 skip shift eliminator will fix that and was the first and best mod I've done.
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
05-07-2018, 02:13 PM | #5 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
When you come off the clutch are you still accelerating, giving it any gas? The drive train does get clunky if you release it while under load. If doing it during acceleration that's not normal.
05-07-2018, 02:16 PM | #6 |
It's 50/50. As I'm coming off the clutch I give it gas. I've always had stick shift cars but FWD. This is my first RWD. Not used to having a drive shaft.
05-07-2018, 05:07 PM | #7 |
for some reason its not letting me post videos.. keeps getting declined
05-09-2018, 11:53 AM | #8 |
OK update on the drivetrain. Chevy looked at it today and they said everything was in perfect condition. They drove it 2 miles and said everything was great. Checked all bolts/nuts also.
05-09-2018, 08:16 PM | #9 |
700RWHP-650TQ
well that sucks...
05-17-2018, 02:19 PM | #10 |
Drives: 2014 2SS/RS Join Date: Dec 2014
Chevy is telling you the truth!
My 2014 ALWAYS has bucking, clunking, shudder in 1st/2nd gears driving in parking lots or stop-and-go, even when brand new. Took me a lot of practice to adapt to the finicky drive-train to lower the occurrence. The giubo couplings on EACH end of the driveshaft are designed to absorb a lot of energy when loaded - like storing energy in a rubber band, huge rubber pucks. (photo below) When the energy is suddenly released (during manual shift) the giudo causes the driveshaft to rotate quickly and slight play in the transmission gears causes a clank and shudder. Also causes jolt and surging when lugging at low rpm in parking garage for example. Due to high HP, these energy absorbing giubo couplings are used to help absorb shock and keep things from breaking versus using a plain universal joint on engine and differential ends.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
05-17-2018, 06:16 PM | #11 | |
Wow thanks for the details.That's awesome!
05-17-2018, 06:22 PM | #12 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
I've been driving my '11 SS since 2010 & initially I had similar symptoms. I found that I needed to finesse the pedal a bit more & give slightly more gas. I removed the clutch return spring & that made launches a bit easier.
05-17-2018, 08:00 PM | #13 | |
376 cubic inches of fun
