05-11-2018, 03:13 PM | #1 |
Drives: 2010 SS, 4.11s, 550, cam and heads Join Date: Sep 2017
Anyone ever found chunks of steel like this in oil pan?
I had the oil changed my car today and had large chunks of steel in the oil pan.
I found some small flakes in the oil afterwards so I’m assuming a new engine is in my future, but despite the flakes and chunks that were found as far as anyone else could tell the car is running perfect. No knocking, low oil pressure or any other indicators. Just wondering if anyone would be able to give me a guess on what it could be? |
05-11-2018, 03:17 PM | #2 |
'It's an experiment'
Valve stem seals maybe? Have you installed valve springs?
Pull valve covers and ck springs and seals... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 05-11-2018 at 03:34 PM. |
05-11-2018, 06:32 PM | #3 |
No haven’t had time to really take a look at it yet. I’ll be sure to check that. Thanks
05-13-2018, 06:50 AM | #4 |
Looks like it could be pieces of a rocker trunnion retainer. if you still have the factory rockers that is.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
05-13-2018, 10:39 AM | #5 |
Heck yea, that could be it also. I don't think he found needles but if he did, that would also lead to the valve train. Looks like pulling the valve covers is the right thing to do either way...
-Don
747 RWHP 794 RWTQ
05-15-2018, 02:12 AM | #6 |
Perfect thanks! Hopefully I can get some time to take the covers off tomorrow.
05-16-2018, 03:02 AM | #7 |
Drives: 2010 ABM 1SS Join Date: Nov 2014
hard to tell but definitely not good.. I would do what other suggested, pull the valve covers and throughly inspect. If it was a rocker, Im surprised there wasn't any bearings
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s |
05-16-2018, 07:34 AM | #8 | |
GPI Sales Consultant
Definitely pull the covers before you run it. And let us know what you find!
Got a question about a GPI product? Feel free to shoot me a message! |
05-16-2018, 08:40 AM | #9 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Definitely looks like a trunion issue. Pull the valve covers and check your rockers asap.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-16-2018, 08:11 PM | #10 |
I got around to pulling the valve covers off last night and everything looked mint still. All the retainers were still in place and nothing looked worn. Any other ideas? I had the oil filter cut open as well and there weren’t many flakes in the filter. Also, would the flakes in the oil be more of a brass colour if it was a bearing? I’m guessing I’m just catching the beginning of what ever is failing. At this point I’m debating just rebuilding the engine and putting forged rods and pistons in it.
05-17-2018, 04:39 AM | #11 |
It could be a lifter... you might be able to take the rockers off and remove the pushrods and look at them with a inspection camera ( can rent one from most parts stores), if not you'll have to pull the intake and valley cover and look at them..
2010 Aqua Blue 1SS
Tags |
steel in oil |
