08-10-2016, 08:59 AM | #1 |
High Angle Hell
CEL came back AGAIN
So I had been reading a lot about what mods need tunes and which ones don't. I thought I could get away with deleting cats with cat delete mid pipes without getting a tune. Maybe I was wrong. I replaced cats with JBA midpipes and knew that I would throw a code which after 3 engine cycles I did. Ordered extenders from BDG and was able to only install one because the other cross threaded. Got a CEL again because I still had one not installed. bought a tap/die set fixed the midpipe bung had to buy another 02 sensor. Replaced that and added the 2nd extender. Had been running fine for the last 400 miles or so and then I get another CEL this morning on the way to work. Not sure what the problem is. IS anyone else running the BDG extenders with JBA noncat midpipe had the same issue as me or should I replace the other o2 sensor? I'm not the worlds best mechanic but I know everything is installed properly with no leaks
Brothers don't always have the same mother Always remembered, Never forgotten |
08-10-2016, 09:05 AM | #2 |
Drives: 2014 Camaro SS - 2SS, RS Join Date: Jan 2014
you removed cats.. you're going to get trouble codes and CEL no matter what.. you need a tune to disable the codes..
08-10-2016, 09:09 AM | #3 |
GPI Sales Consultant
Let's start with what trouble codes are setting, that'll give us some direction into what the root issue may be.
Got a question about a GPI product? Feel free to shoot me a message! |
08-10-2016, 09:10 AM | #4 |
High Angle Hell
see and from what other people were saying on here they there are the JBA midpipes and another brand(cant remember). everyone that bought the JBA said they were doing fine after installing O2 extenders from BDG. The ones that installed the other brand had to tune even with the extenders. UGH
08-10-2016, 09:12 AM | #5 |
High Angle Hell
Im going after work to figure out what codes are actually being thrown. At this point I'm just assuming that it has something to do with my O2 sensors because that's what its been the last couple times
08-10-2016, 09:36 AM | #6 |
I agree, I have no doubt it's O2 related, but which ones might give us a clue if this is your typical O2 sensor/header problems, or if it could be a damaged sensor, wire, etc.
08-10-2016, 10:01 AM | #7 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
The extenders don't ALWAYS work, they are moving the o2 sensor so that the reading fools the computer.
Your honest best bet is a tune. Is there a reason why you are avoiding it?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
08-10-2016, 10:32 AM | #8 |
Your car will need to be tuned like dyno Steve said
Rear O2's need to be within a certain temperature and without the cats they will not get to that certain temperature and throw a code
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
08-10-2016, 11:00 AM | #9 |
High Angle Hell
08-10-2016, 11:01 AM | #10 |
High Angle Hell
Not trying to tune my car a bazillion times. That and the closet one that is reputable is 2 hrs away in Atlanta
08-10-2016, 11:03 AM | #11 |
That will need a tune to compensate for - standard issue you get with headers and or hi-flow/no-cat. A tuner can essentially over-ride the readiness test so that you won't get the CEL.
08-10-2016, 11:48 AM | #12 |
High Angle Hell
Understand I'm running stock headers. Just have CAI, ported TB, JBA midpipes, and ATAK exhaust.
08-10-2016, 12:02 PM | #13 | ||
Once we start taking the system away from stock we change the response of everything, and the "in-spec" range in fairly narrow to begin with. A tune can compensate for these things in a number of ways. With rear O2 sensors, they are usually just tuned "out" so that they are never a problem.
08-10-2016, 01:05 PM | #14 | |
Honestly, I feel like you would be fighting a losing battle by modifying without a tune. How much more do you have on your mod wish-list that would require a retune?
