Old 01-20-2014, 04:02 AM   #1
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
Strut Tower Brace for us V6 guys?
May be a dumb question but are there any strut tower braces out there for us V6 guys? Everything I can find is for the SS however from the look of it, it seems as though since they are just bolt on a SS one would fit fine. If so, maybe post of some pictures of the ones you guys have!
Thanks!
Aaron
ArmyEOD17 is offline   Reply With Quote
Old 01-20-2014, 05:36 AM   #2
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
Any of the SS braces will fit the V6. Many of the suspension gurus here will say that the Camaro coupe doesn't need one, so it would be a "mostly-for-looks" mod.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 01-20-2014, 06:35 AM   #3
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Bmr has a great strut brace
chevy 3 is offline   Reply With Quote
Old 01-20-2014, 06:56 AM   #4
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
I see one in most pictures its basically one solid wide support bar and everyone custom paints them, would you guys happen to know which it is? And thanks for the info also!
Old 01-20-2014, 07:01 AM   #5
dmginc
dmginc's Avatar
Drives: In Circles
i have the BMR one on my v6, it is not just for looks like the Chevy one.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 01-20-2014, 07:52 AM   #6
pgustavson
pgustavson's Avatar
That is probably the OEM convertible strut tower brace:
http://gmpartsdirect.com/results.cfm...ber=pkcamarobr
Old 01-20-2014, 09:21 AM   #7
intensifi
Drives: '12 2LT Convertible
Your car should already have the threaded holes for the OEM brace. 3 holes on each tower.
My '12 2LT convertible came with one.
They appear for sale in the member sale section front time to time also.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 01-20-2014, 10:36 AM   #8
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
Yes thats the one! thanks pgustavson! The BMR one is a looker too though.
Old 01-20-2014, 11:29 AM   #9
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
I can't decide rather to go with the GM or BMR brace lol
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 01-20-2014, 12:08 PM   #10
montreal2010yellow
montreal2010yellow's Avatar
Other option
I installed Hotchkis srtut brace mostly because of the attachment points are located on each side of the tower instead of being attached on the top.
Takes more time to install and better have a good mechanic to do the job since drilling requires Professional Tools, Garage jack, and a very good compressor with a very goog quality drill. The metal is really tough there.
And it leaves more clearance for the engine cover.
As for performance, I felt the difference on the very first curves I took at 65 mph. Really different.
And it looks good.
Name:  strut éclairé 01.jpg
Name:  engine bay hotchkis 2.jpg
Old 01-20-2014, 01:48 PM   #11
delta6
USN-MSC
delta6's Avatar
Drives: 2012 Camaro TF3 #427
GM, BMR, Hotchkis, PFADT, etc have strut tower braces that can fit both v6 and v8 camaros...2012 and up have pre drilled holes already...I don't know about 2011 and below. I know some guys have problems with their earlier model camaros. Any "suspension gurus" will tell you that if you're keen on making your turns smooth then get a strut tower brace as this will stabilize your front end suspension. As far as performance, this will help the body from flexing thus helping you with your track times... if you're not going to race, you will still feel a slight difference. Bottomline, it will still help you either way. If you're into racing, I would suggest getting a chassis max brace for more stabilization...among other things.
“The winner ain’t the one with the fastest car, it’s the one who refuses to lose.”
delta6 is offline   Reply With Quote
Old 01-20-2014, 03:02 PM   #12
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
Thanks delta makes a lot more sense now!
Old 01-20-2014, 04:01 PM   #13
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Keep in mind if you plan on and add a manifold spacer,which will raise it and shorten the clearance between the brace and intake. Just an fyi
Old 01-20-2014, 04:04 PM   #14
Infidel67
Life's just a Ride
Infidel67's Avatar
I just ordered the BMR one, got a nice deal from RDP Steve
