Old 04-10-2014, 08:19 AM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Learning the hard way about short front tires
Well I setup my car with Weld RT-s 17 rims. ABS/Traction control light on now. Found out by using the shorter height front runner tire makes the ABS system see faults. From what I'm learning no way to recalibrate for this. So now A christmas tree of warning lights on my dash, brake pedal buzzing/pulsates for the first several stops. I'm a bit pissed that after almost $4,000.00 for rims/ tires/ control arms, I wished the vendor would have stated this situation to me. Just figured I would share my situation anyone else know a way around this let me know. I use HP Tuners and have been told nothing they can do.
etmx183 is offline   Reply With Quote
Old 04-10-2014, 09:08 AM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Can you pull the ABS fuses?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-10-2014, 09:15 AM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Replace the front tires to ones that have the same diameter as the rear and your problem will go away. Pretty much common knowledge about these cars.
The Bird is the word!
Old 04-10-2014, 11:26 AM   #4
Denis
Denis's Avatar
Drives: 2010 SS
both of those are very easy solutions to your issue.
whats the height on the tires that youre using?
Old 04-10-2014, 11:29 AM   #5
Angrybird 12
I think if you pull the abs fuses you will still get all the lights because the computer will still see a problem because it uses the abs signal for stabilitrac too.
Old 04-10-2014, 11:40 AM   #6
jvoisel
Drives: 2010 2SS/RS M6
Pull the fuse and you should only have to deal with the lights.
What size tires are you running front and rear?
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 04-10-2014, 11:48 AM   #7
Blk_SS
Drives: black on black 2SS/RS
It you pull the fuse wouldn't it disable your abs?? I think op would like to have abs but not the lights
Blk_SS is offline   Reply With Quote
Old 04-10-2014, 12:38 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, anything more than a 6% difference in tire diameter, front-to-rear, will cause issues. Most people try to stick within a 1/2", front-to-rear, just to be safe. Mickey Thompson has just released a Sportsman S/R (28x6.00R17) radial that works great with the 28" rear tires.
Old 04-10-2014, 01:19 PM   #9
etmx183
etmx183's Avatar
Thank for the input folks, you live and learn. I'm going to look into the M/Ts to solve this issue. I'll pull the fuse for now to quit the brake pulsation for now. ( 26" tall ) P185/55R17 M&H front runners & ( 28" tall ) P275/50/17 Rear tires is my current setup.
