11-20-2012, 08:24 AM | #1 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
Who has the Torq Supercharger Innercooler tank with Drag Cap Installed?
Has anyone used one of these or another brand that could provide feedback? I'm Mostly curious how well it worked at keeping the Air Intake Temps down when packed with ice for 1/4 mile use, and also how well it worked for overall street use. I already have the Torq dual pass Heat Exchanger with fans and am going to add the Torq ZL1 Innercooler pump upgrade. I have a Maggie running 14 lbs at Mile-Hi elevation, but other roots style superchargers before/after results would definitely apply.
I don't trailer and need room to load slicks in the back seat & trunk, plus do club road trips & Cfest with the slicks/luggage/tools - so above battery in trunk is out. Only other option is a custom fabricated tank that would mount below the trunk by the battery and ditch the air pump. http://www.gettorq.com/store/chevrol...tank-torq.html
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . Last edited by Blue70SS; 11-26-2012 at 09:22 AM. |
11-20-2012, 08:37 AM | #2 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Cant give you anything positive for the tank since it would not fit right with my setup and I wasnt to happy about deluting my coolant by adding ice so I returned it for torqs dual pass HE with fans. That works like posted and really keeps temps down.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
11-20-2012, 09:13 AM | #3 | |
Also might step up the speed by overdriving the harmonic balancer - currently 3% underdrive, +3% and +6% shells available. Controling heat will definitely have to be addressed if I persue more boost.
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . Last edited by Blue70SS; 11-20-2012 at 09:32 AM. |
11-20-2012, 10:43 AM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
We run ice in our 7 second drag radial car, keeps the temps down. I don't see a 160 thermostat in your list of mods, I would do one. Heat is your enemy.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-20-2012, 11:05 AM | #5 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
We use those on the big HP builds and it is a great help....but if you want to really address it look into our RX Super Chiller. Not a hard install.....adds very little weight, and will keep IAT's far lower than any ambient air temp solution can. Were seeing temps in the 30's and 40's now it is in the 70's here.
11-20-2012, 06:32 PM | #6 | ||
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
11-21-2012, 05:09 AM | #7 |
Drives: 2010 SS RS Join Date: Apr 2009
Has anyone used the Torq reservoir with a DeWitts/BeCool radiator? Wondering if the added depth of the radiator allows for adequate clearance to the pulley/tensioner if the reservoir needs to be offset a little to clear the top radiator tank.
11-23-2012, 11:04 PM | #8 |
bump
11-30-2012, 09:42 PM | #9 |
Nobody has a Torq reservoir?
11-30-2012, 11:27 PM | #10 |
Drives: ABM SS/RS Join Date: Sep 2009
Ive been trying to get one since March but keep being told they are redesigning the tank. So far, still no tank. :(
12-01-2012, 10:16 AM | #11 |
We have the RX Super Chiller on builds in the 700-800 rwhp range working awesome.
12-02-2012, 11:53 AM | #12 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
From everything I have been hearing good luck on getting anything from Torq right now,lol.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
