Old 03-28-2020, 09:08 PM   #1
sickspeedSS
Drives: 2010 Camaro SS M6
Tire size question
I came across someone saying running to short of a tire will cause issues with stability control/traction control and ABS. Can someone shed a little light on this please? I’m lowered about 1 1/4 on 18 x 10 Forgestars square setup running 285/40’s all the way around. Is it something that can be adjusted in the tune??
sickspeedSS is offline   Reply With Quote
Old 03-28-2020, 09:31 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
It's only if you have a difference between front and rear. You are running square so no issues at all.
If you have ~1.4" tire height difference or greater you start having issues but you're good.
Old 03-28-2020, 09:44 PM   #3
sickspeedSS
Good deal!! Thanks a lot sir I really appreciate it.
Old 03-28-2020, 10:08 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Old 10-19-2020, 01:51 PM   #5
Aheadau
Drives: 2014 Camaro Ss 1LE
I am getting some new tires this week, and I will have about 1.2" difference between front and rear. Anyone know if this will be enough to give me any issues?
Aheadau is offline   Reply With Quote
Old 10-19-2020, 02:35 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I am running 275/35/20 front and 315/35/20 rear and it is 1.2 difference and no issues. Been running them for about 6 months now. You should be fine.
Old 10-19-2020, 03:07 PM   #7
Aheadau
Ok, awesome. I appreciate the help.
Old 10-20-2020, 02:28 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Most welcome ...
Old 10-20-2020, 02:49 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Here's a really good thread on Tire Sizes...
https://www.camaro5.com/forums/showthread.php?t=62838
Old 10-20-2020, 03:50 PM   #10
gsxrturbo
Drives: 2010 ss
Thy say 3% difference between fronts and rears. Or about 1"
gsxrturbo is offline   Reply With Quote
Old 11-01-2020, 03:36 AM   #11
bottletalk
Drives: 15 Camaro 2SS M6
Are you running staggered 9 &10's?
bottletalk is offline   Reply With Quote
Old 11-01-2020, 10:18 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir, 20x10 front and 20x11 rears..M228's...
Old 11-01-2020, 04:52 PM   #13
bottletalk
that’s the size I’m wanting to go, does your rubber hang outside the quarter panel at all or rub inside the wheel well? do you recall the rims offset?
Old 11-02-2020, 09:44 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Both front and rear tires and wheels are even with the fenders, no outside hang and no inside rub at all. The wheels are stock offset for the Z28's, being +23 front and +43 rear's.
