02-22-2014, 06:07 PM | #1 |
QTP cutout motors
Anyone ever had there motors off and opened up? Obviously, there not intended to be user serviceable, but can they be? Are the motors gear reduction, or do they drive the valve directly?
Mine have started to act stupid. Sometimes they'll work, sometimes they won't. I'm going to check the wiring tomorrow and hope it's a bad connection or switch. Seems this all started after I washed the underside real good after driving on some salt covered roads. Hopefully they just need some attention.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
02-22-2014, 06:12 PM | #2 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Same thing here, until the other day they stopped working all together...
They require periodic cleaning, mine stopped working the other day after trying a new switch and then pulling them I tested the motors using my battery They worked fine, So now I pretty much 100% sure my Iwire is the culprit... and QTP is sending me a new one for free. These motors also need to be sprayed with something like WD-40 time and time again to avoid premature wear and to keep the exhaust residue to a minimum to avoid leaks. This goes for any cut out not just these. Run a + and - wire to the plug connection just unplug them and youll see the 2 pins inside the plug to test them they are dual polarity so doesn't matter what pin you put the power too it will either close or open depending on that.
02-23-2014, 04:22 PM | #3 |
Removed and opened both motors today. Bad news is that both motors have striped gears in them. There not designed to be user serviceable, but a determined person can handle it. Going to order at least one replacement motor and do some mix and match to repair the other one. Should have some spare parts left if this happens again.
02-23-2014, 08:47 PM | #4 | |
02-23-2014, 09:52 PM | #5 | |
Vrrrm.
Sucks motors are like 40$ a pop too. Any pics of them deasembled im also curious about it.
02-24-2014, 07:18 PM | #6 | |
"Do NOT use wd40 as that's a waste. Wd40 is 70% water and will just evaporate. Instead use "liquid wrench" you can find it at Walmart or any auto parts store. I spray mine down on the shaft coming from the motor that opens/closes the butterfly at Least every month and they've been going strong for 6 yrs now" |
02-25-2014, 09:31 AM | #7 |
Cutouts are just over a year old and the car is not a DD but is driven often. I contacted QTP yesterday and there sending me 2 new motors. Cutouts are out of warranty, but there helping me out some.
I usually hold the switch until there open or closed. Going to have to change my technique some. There is supposed to be an over torque fuse in the wiring harness, but mine never blew. When I install the new motors, I'll post some tear down pics of the old ones. I'm going to strip them of good parts in case this happens again. I was in a rush last time. I understand things happen and this hobby is expensive. QTP also offered to do a full refurb on them if I would send them in, but I elected to just have them send me the motors. I'm satisfied with the way QTP handled things.
02-26-2014, 05:42 PM | #8 | |
02-26-2014, 06:12 PM | #9 |
Taking care of me is an understatement. They sent my motors 2nd day air! On there dime!
02-28-2014, 12:49 PM | #10 |
