10-08-2014, 06:01 PM | #1 |
Drives: 2013 2SS Join Date: Mar 2014
60 - 75 HP?
I have a CAI on order. LT headers are next along with a tune. What size cam would I need (although I'm a bit hesitant on a cam right now with all the problems people seem to be having with aftermarket cams)? I would like a little bit of lope at idle. I don't know how bad the low rpm bucking/surging on something like the Night Fury cam would be but I am thinking perhaps something in between the likes of the NF cam and stock would be about right. I want to pick up 60-75. Thoughts?
10-08-2014, 06:06 PM | #2 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I ran the lpe gt1 cam, it is very mild and it made 444/424. With amazing driveability. You can even use stock springs and pushrods. Making it very cheap to cam. It sounded great too. Might want to check it out. I had under 450 bucks for the cam swap doing it myself plus tune
10-08-2014, 06:10 PM | #3 |
I ran the gt11 on my l99. With supporting mods it put down 443rwhp. I'm now running a gt9 on my new engine. The gt11 was nice, subtle, drive like stock.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
10-08-2014, 06:16 PM | #4 |
Are you guys talking about the same cam and if so which is it - gt1 or gt11? 443 at the wheels sounds nice!
10-08-2014, 06:19 PM | #5 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Check with Brian Tooley
OLD GUY FLYING FAST AND LOW
10-08-2014, 06:21 PM | #6 | |
If you have a automatic, you need to do the ls3 conversion imo
10-08-2014, 06:22 PM | #7 |
I ran the gt1 thru a m6, he ran a gt11 thru an a6
10-08-2014, 09:33 PM | #8 |
Drives: Camaro and Sierra Join Date: Jul 2012
10-08-2014, 09:58 PM | #9 |
I did a reverse delete
10-09-2014, 07:32 AM | #10 |
Drives: E92 BMW M3 Join Date: Oct 2012
Like many people will tell you around here, go with a custom spec cam.
I had similar goals to you, I wanted a nice stage 2 cam idle with excellent street manners but I just wanted great torque and wasn't concerned with chasing a HP number. I went with a Pat G custom cam ground on cam motion lobes. Cam is a 226/232 112+4, which is much smaller than a Night Fury(236/242 I think, but don't quote me). My cam put down 476/446 on a hot humid Houston day, which really surprised me and it drives almost like stock with a mean idle chop. For some comparison I dyno'd 417/410 with long tubes, intake, and a tune. Good luckin your choice man.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
10-09-2014, 10:30 AM | #11 | |
Drives: '14 1le Join Date: Jan 2014
10-09-2014, 10:42 AM | #12 | |
Drives: 2012 Camaro SS 45th Anniversary Join Date: Sep 2013
i did a custom grind Comp Cam stage IV (picked up 78 rwhp) - DOD delete, LS3 conversion from L99. low rpm it definitely bucks, but i love it, idle sounds amazing. I'm at 400hp. here's vid "idle"
talk to Ivan @ Southwest Speed - Alb, NM #SWS #southwestspeed bishes
~ 2012 SS ~ |
10-09-2014, 06:21 PM | #13 | |
10-09-2014, 06:22 PM | #14 | ||
