01-20-2012, 11:18 PM | #1 |
SWFLGENS
Is it bad to go from 245/45 to 245/40
I'm not smart about tires but certain tires do my 245/45 then some do 245/40 does it effect the car
SWFLGENS on facebook. |
01-20-2012, 11:45 PM | #2 |
Searchin' ....
What are you trying to do? Are you just getting a tire replacement?
01-21-2012, 12:49 AM | #3 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
The 245/40 are almost an inch smaller in diameter.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
01-21-2012, 07:41 AM | #4 |
SWFLGENS
Yea I am getting tire replacement and I was wondering why if you change 45 to 40 the choose of tire is so wider and has anyone got 245/40 falken tires ?
01-21-2012, 10:06 AM | #5 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
YES it would affect your car......actually if you go fron 245/45 to 245/40 when your speedo reads 60 mph.....you actually running 58 mph which will affect your odometer as well. AND your MPG.
01-21-2012, 12:08 PM | #6 | |
Quit being a pu$$y
275/40 is the stock sized rear tires, so I assume he is just talking about replacing the fronts. The rear tires are the only ones that affect the speedometer and odometer. Going with 245/40 front tires will affect your MPG a tiny bit. It will actually INCREASE you MPG because the smaller tire will obviously be lighter and a lighter rotational mass takes less power to turn. Also some people will say that it will affect your stabilitrac or ABS, it won't. The BCM has to see a variance of 6% at speeds greater than 62 mph to set off any codes. With 245/40 20 fronts and 275/40 20 rears you will only be at a 3.4% difference. I have a TON of experience over the years with different tire sizes. Hell, I've had EIGHT different size tires on Ginger!
01-21-2012, 01:00 PM | #7 |
SWFLGENS
thank you guys for all the help that's why i always come here wit my stupid questions :<)
01-21-2012, 01:10 PM | #8 |
Quit being a pu$$y
Feel free to ask as many questions as you want, I always say "No such thing as stupid questions just stupid answers."
01-21-2012, 01:11 PM | #9 |
Drives: Camaro SS Join Date: Mar 2011
The 245-40 is 1" shorter then the 245-45. Unless you are planning on lowering your car severly there is no advantage in the shorter fronts. Especially, since you havent mentioned your plans for the rear.
Plus, you will end up with alot more fender gap on the car then what you have now. Which is silly. All things being equal, you are better off keeping the same front size as factory. |
01-22-2012, 12:45 AM | #10 |
01-22-2012, 02:13 PM | #11 | |
05-02-2016, 12:23 AM | #12 |
Drives: Camaro 2SS RS Join Date: Oct 2014
I have Havoc wheels (8x20 and 9x20) with KW V3 coilover.
I' d like to put: 245 40 20 on the front and 275 40 R20 (stock size) on the rear Or 245 35 20 on the front and 275 35 R20 on the rear Will I have affect my stabilitrac or abs? Thank you!!!!!!
05-02-2016, 10:07 AM | #13 | |
Recommended 20" tires for 2010 Camaro 245/45-20 = 28.7" tall, 8.0-8.5 wheel 255/45-20 = 29.0" tall, 8.0-8.5 wheel 265/40-20 = 28.4" tall, 8.5-9.0 wheel 275/40-20 = 28.7" tall, 9.0-9.5 wheel 285/40-20 = 28.9" tall, 9.0-10.0 wheel 295/35-20 = 28.1" tall, 9.5-10.5 wheel 305/35-20 = 28.4" tall, 10.0-10.5 wheel 315/35-20 = 28.7" tall, 10.5-11.0 wheel
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
05-02-2016, 11:19 PM | #14 | |
Similar Threads | ||||
What song are you listening to right now | Muscle Master | Off-topic Discussions | 6730 | 04-13-2024 11:56 AM |
DT Shorty and DT Exhaust Good News Bad News... | Synergy SATX | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 21 | 06-20-2010 09:49 PM |
Bad power steering pump and the police. | Big Brunsy | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 9 | 06-16-2010 09:00 AM |
How bad are burnouts? | boomskeet | Dragstrip and Launch Techniques Discussion | 8 | 04-27-2010 10:10 AM |
bad personal news | ChevyNut | Off-topic Discussions | 4 | 02-23-2007 11:36 AM |
