03-19-2016, 06:42 PM | #1 |
Drives: '11 2SS/RS L99 Vert IO Interior Join Date: Nov 2015
X-Pipe and High Flow Cat Installation Costs? Tune needed?
I want to get high flow cats and x-pipes installed in my 2011 SS. How much should the installation cost be if I supply the parts? It's stock except for Flowmaster mufflers and K&N CAI. Also, would it cause enough changes that I would need a tune or new O2 sensor?
03-19-2016, 06:44 PM | #2 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
Might as well do the headers too and then tune it.
03-19-2016, 06:46 PM | #3 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
no tune...for me around 850 for both installed.
03-19-2016, 06:55 PM | #4 |
03-19-2016, 07:43 PM | #5 |
Take the 850 get headers and a tunner for a bit more and do it yourself. A couple hours of your time and you will have more horse power and better sound
03-19-2016, 08:16 PM | #6 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
OP-you have a convertible. Are you aware that changing the mid-pipe will probably foul the vert's chassis bracing? When I was researching headers for my vert,I ended up leaving the OE H pipe in place so that i did t have to buy an aftermarket brace. IIRC, ARH's brace was $475+labor.
I got a very nice result with ARH headers w/HF cats into the OE mid-pipe and NPP. Plenty of power. Sounds just right (you know it's modded but not obnoxiously loud). And you will want a tune just to make sure your air/fuel mixture is spot on. Do a ported throttle body while you're at it.
Consensus is, by definition, a lack of leadership.
03-19-2016, 08:59 PM | #7 |
700 hundred for the cats including install. Sorry that should be $950. The x pipe was 250 installed. No sensors needed. Op the solo hi flow cats will give you better sound then headers. But long tubes with a tune is a good choice also.
