Old 06-05-2016, 02:41 AM   #1
pir4te
Moonshiner
pir4te's Avatar
Drives: Holden SS-V L77 flex fuel
180° Headers
Anyone here put a set of tuned crossovers on their LS? Dyno / Videos?
Compression is King.
Naturally as-pirated, all-motor, all alcohol.
pir4te is offline   Reply With Quote
Old 06-05-2016, 02:46 AM   #2
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Do you have any idea how difficult it would be to even attempt to fabricate a set of 180 deg headers for a front engine, rwd chassis? The only vehicles I'm aware of that can even attempt this is in a rear engine chassis like the old GT40 and Pantera. Besides that, the cost is not worth the gains. The sound would be extremely similar to the GT350 Voodoo engine.
From an exhaust fabricator stand point, the first thing you're gonna run into is trying to keep the pipes the same length. With 4 pipes crossing over to the opposite side, that will be nearly impossible. The second issue is where the hell are you gonna put them? Regular 4-1 headers meeting into a properly designed x-pipe will be very similar and sound good as well. Let's not use a crane to change a light bulb in the bathroom. . . .LOL.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 06-05-2016, 03:36 AM   #3
pir4te
Moonshiner
pir4te's Avatar
180° Headers
Thanks for getting back, yeah sound is important - this is a sonic experiment - gas particle flow has been sufficiently addressed with tuned PWTBs. My target is not 180° to promote flow through pulse separation, rather to reflect the sonic wave +90°, to hit next cylinder during overlap.
I've played with a few different off-the-shelf headers and PipeMax, now after doing the math am fabricating crossovers based on LS firing order 4-2-1s (Tri-Y).
Seems doable with just two ceramic coated crossover pipes underneath. Preliminary fitting and thermal issues addressed last week, should have a reasonably true prototype running mid week.
I am expecting it will sound like a Pantera but could well be closer to a Briggs & Stratton!
Old 06-05-2016, 05:05 AM   #4
2010reddevil
Haha well good luck! It's gonna be a hell of a challenge, if it's even doable.
Old 06-05-2016, 08:24 AM   #5
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I've been eyeballing 180 degree header setups for a long time. With our given chassis configuration, I'm not entirely sure how it could be routed and still be efficient. However, a very quick search on YouTube will result in finding an old video of a C5 Corvette with 180 headers.
Either way, I'd be highly, highly interested if a company came out with a set that actually worked. Mayhaps a design such as this?
2018 Audi TT RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped).
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
2021 Charger Hellcat Redeye Widebody
Sold
USAFS197 is offline   Reply With Quote
Old 06-05-2016, 09:12 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Yes what a wonderful way to heat the oil and fry the starter more than is already inherent with headers..... I am on my second starter... And this would absolutely be a bear, let alone a oil pump change would be further complicated as ..... But hey someone has to try everything at least once so we can learn from their mistakes if they just post what happens down the road..... does it make the oil hotter than a pistol, sure flows a little better and scavenges better but could cause a bunch of other things.....
You do know Pfadt is back in operation? and = does make tri y's....... they went out of business and now have been absorbed by another company in CAL....you may want to google them, they are worth it if your that obsessed with a few HP....
Old 06-05-2016, 09:12 AM   #7
pir4te
Moonshiner
pir4te's Avatar
Yes I saw that for SBC firing order, thanks.
One result with 180° opposed firing is better spaced pulses, but that's a side issue to me as I can manage gas particle flow, velocity and the double-pulse adequately with a tuned termination box per bank.
My idea to use crossover pipes is to fire sound waves back at more useful cylinder ignition intervals; clear header tube before EVO (+90°), into the chamber during Exhaust (+180°) and IVO/EVC extract on overlap (+270°).
A racing team here in the V8 Supercar series did a similar thing a couple of years back.
Old 06-05-2016, 09:27 AM   #8
pir4te
Moonshiner
pir4te's Avatar
You do know Pfadt is back in operation and = does make tri y's.......
Yeah hi again, I'm that pirate who takes the compression up to 14:1, installs VVT, tweaks AFM, does 35k miles a year on e85 and discount methylated spirits from the hardware store. 35+ MPG on ethanol, 630 BHP.
I have made a couple of tuned header systems before, so regarding heat in the section underneath, there is no issue with engine or trans oil and nowhere near the starter. Crossovers are ceramic coated, and flanged for separate remove / refit.
Pfadt are good, don't really fit the bill with ideal dimensions, cost and availability. And they don't crossover.
Old 06-05-2016, 11:36 AM   #9
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
pir4te, if you do make some crazy 180-degree headers, PLEASE post a good quality video.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 06-05-2016, 12:20 PM   #10
USAFS197
USAFS197's Avatar
That was just a visual aid example, not necessarily something I'd like to fit in my particular vehicle. Also, I have zero interest in Pfadt (aFe) and their headers.
2018 Audi TT RS
2019 Audi RS3
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 06-05-2016, 12:32 PM   #11
Gearheaded
Gearheaded's Avatar
Drives: 2014 SS
I've seen videos of them on corvettes, sound truly amazing. I was always curious why it couldn't be done at the collectors, instead of the actual headers.
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET)
2000 Trans Am - Bolt-ons 13.0@110 (sold)
2009 YZF R1 - Race bike (road course)(totaled racing)
2008 YZF R6 - Race bike (road course)(still own)
Gearheaded is offline   Reply With Quote
Old 06-05-2016, 12:37 PM   #12
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Subscribed.
Old 06-05-2016, 03:22 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Sub'd
Subscribed.
Same here
Orange Krush II
Old 06-05-2016, 07:07 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I'd love to get 25+MPG on regular old 93 octane. Care to share any tuning tricks with a novice tuner? Sounds like you have a hell of a car, by the way!
-Scott
-Subscribed, also!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
